A4 B8 Ошибки А4 В8 - помощь в расшифровках
Тема в разделе "A4", создана пользователем Max_001, 15 сен 2013.
  1. Max_001
    Max_001 Участник форума
    2 июл 2013
    163
    A4/B8 2.0 TDI 08г.
    Добрый день! проверяли по ваг ком машину на наличие ошибок. выдало вот некоторые, обьясните пожалуйста.
    Address 02: Auto Trans (J217) Labels: 0AW-927-156.clb
    Part No SW: 8K0 927 155 AF HW: 0AW 927 156 G
    Component: 0AW 20TDI RdW H01 0006
    Revision: --H01--- Serial number: 0000000587
    Coding: 000002
    Shop #: WSC 06335 000 00000
    ASAM Dataset: EV_TCMVL381 A02005
    ROD: EV_TCMVL381_AU48.rod
    VCID: 77F9EFEF7F5D
    2 Faults Found:
    2225 - RPM Signal from ECU: No Signal
    P0727 00 [032] - Upper Limit Exceeded
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 0
    Fault Frequency: 8
    Reset counter: 32
    Mileage: 0 km
    Date: 2000.00.00
    Time: 00:00:00
    2285 - Hydraulic Pressure Sensor 1 (G193): Adaptation Limit Reached
    P1775 00 [032] - Check DTC Memory
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 8
    Reset counter: 32
    Mileage: 0 km
    Date: 2000.00.00
    Time: 00:00:00
    ddress 08: Auto HVAC (J255) Labels: Redir Fail!
    Part No SW: 8T1 820 043 AA HW: 8T1 820 043 AA
    Component: KLIMA 1 ZONE H06 0140
    Revision: A1000000 Serial number: 0124.05.080709
    Coding: 34000000
    VCID: 70EBD4F31A33
    1 Fault Found:
    01271 - Positioning Motor for Temperature Flap (V68)
    001 - Upper Limit Exceeded
    Freeze Frame:
    Fault Status: 01100001
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 74
    Mileage: 85035 km
    Time Indication: 0
    Date: 2013.09.15
    Time: 01:14:53
    Freeze Frame:
    Voltage: 13.70 V
    Temperature: 19.0°C
    Temperature: 43.0°C
    Count: 11211
    Count: 12055
    Bin. Bits: 01000000
    Bin. Bits: 00000111
    Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
    Part No SW: 8T0 907 468 H HW: 8T0 907 468 H
    Component: GW-BEM 5CAN H06 0091
    Revision: GB102039 Serial number: 3900G084278835
    Coding: 000303
    VCID: 4687522B4837
    Part No SW: 8K0 915 181 B HW: 8K0 915 181 B
    Component: J367-BDM H04 0150
    2 Faults Found:
    02256 - Quiescent Current
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 8
    Reset counter: 60
    Mileage: 82488 km
    Time Indication: 0
    Date: 2013.07.22
    Time: 17:30:00
    03041 - Energy Management Active
    000 - - - Intermittent
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 18
    Reset counter: 111
    Mileage: 83770 km
    Time Indication: 0
    Date: 2013.08.15
    Time: 16:50:00
    Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
    Part No SW: 8K0 959 793 C HW: 8K0 959 793 A
    Component: TSG FA H10 0170
    Revision: Serial number: 0000007179087
    Coding: 011002204000410001
    VCID: 408B44336A13
    1 Fault Found:
    00446 - Function Limitation due to Under-Voltage
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 114
    Mileage: 85035 km
    Time Indication: 0
    Date: 2013.09.15
    Time: 00:55:50
    Address 62: Door, Rear Left (J388) Labels: 8K0-959-795.clb
    Part No SW: 8K0 959 795 A HW: 8K0 959 795 A
    Component: TSG HL H06 0170
    Revision: Serial number: 0000007144471
    Coding: 010002204000210001
    VCID: 408B44336A13
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 114
    Mileage: 85035 km
    Time Indication: 0
    Date: 2013.09.15
    Time: 00:55:50
  2. DSaiD
    DSaiD Участник форума
    3 май 2011
    492
    A5 SB 2.0T 225hp
    Привет!Вы лучше их сотрите и через часик езды сделайте новую диагностику,вот тогда с ошибками сюда,тут пару старых ошибок,а еще лучше посмотреть эту тему и расшифровать каждую ошибку и не плодить темы http://www.audi-club.ru/forum/showthread.php?t=142982 читать шапку.Так будет удобней и понятней разбираться с каждой ошибкой.
  3. Audi1833
    Audi1833 Новичок
    6 ноя 2013
    36
    A4/B8 2.0T quattro
    Снял логи ошибок моего авто! Кто шарит подскажите по этим ошибкам
    Адрес 07: Блок управления и индикации Label: 8T0-035-7xx-07-H.clb
    Номер блока управления: 8T0 035 729 M HW: 4E0 035 729 A
    Компонент и/или версия: Interfacebox H43 4610
    Кодировка: 0000003
    Код мастерской: WSC 02145 785 00200
    Дополнительная информация: 8T0919609A E0380 BedienteilH08 0100
    Дополнительная информация: Geraet 00200
    VCID: 438EB315028EF9B
    1 неисправность:
    03157 - Ограничение работоспособности из-за нарушения связи
    000 - -
    Стоп-кадр:
    Статус неисправности: 01100000
    Приоритет неисправности: 6
    Частота появления ошибки: 1
    Индекс забывания: 199
    Пробег: 58339 km
    Отсчет времени: 0
    Дата: 2014.02.05
    Время: 13:26:06
    Стоп-кадр:
    Бин.биты: 00000000 10000000
    Бин.биты: 00000000 00000000
    Среда,05,Февраль,2014,13:35:43:10463
    ВАСЯ Версия: диагност 11.11.2
    Версия данных: 20120130
    Адрес 46: Центральный модуль систем комфорта Label: 8K0-907-064-46.clb
    Номер блока управления: 8K0 907 064 F HW: 8K0 907 064 F
    Компонент и/или версия: BCM2 1.1 H80 0141
    Кодировка: 0106023A007A440400B001
    Код мастерской: WSC 02399 823 56573
    VCID: 336EE3D5922E49B
    2 Найдены неисправности:
    02615 - Заблокировать крышку топливного бака
    009 - обрыв или короткое замыкание на массу
    Стоп-кадр:
    Статус неисправности: 01101001
    Приоритет неисправности: 2
    Пробег: 58339 km
    Отсчет времени: 0
    Дата: 2014.02.04
    Время: 17:17:04
    02616 - Разблокировать крышку топливного бака
    Стоп-кадр:
    Пробег: 58339 km
    Отсчет времени: 0
    Дата: 2014.02.05
    Время: 13:25:45
  4. Grafon
    Grafon Участник форума
    18 дек 2012
    104
    А4/ В7 2Т2.0TQ 08
    Не парься просто глюки, скинь их просто и щабудь
  5. Payne_
    Payne_ Новичок
    22 май 2013
    7
    А4/В8 1.8Т 08г.
  6. Sany_OK
    Sany_OK
    3 янв 2008
    2.641
    А6 С7 3TDI 245(300)hp Q
    Не надо пока ничего менять... стереть и пока забыть.
    Вот если действительно глючить замок начнет - разбираться с приводом.
  7. MqZqHqKq
    MqZqHqKq Живу я здесь
    8 фев 2013
    1.446
    A4/B8 Avant 1.8T
    Поддержу ошибки за ошибки можно не считать! Стандартный набор...ничего особенного!
  8. Audi1833
    Audi1833 Новичок
    6 ноя 2013
    36
    A4/B8 2.0T quattro
    У меня лючок странно открывается, приезжаю на заправку открываю дверь, он не открывается! Вытаскиваю ключ, закрываю машину-открываю и только после этого он открывается!
  9. Mixail86
    Mixail86 Новичок
    6 фев 2014
    11
    А4/В8 18Т 11г.
    Народ,подскажите! С утра как всегда завел с авто запуска машинку,А4 2011г,1.8Т,сажусь,завожу машинка троит,загорелся ESP и чек,за глушил по новой завел все тоже самое,решил поехать,ESP погасло,чек остался,на низких трясет машин,еду нормально но чек так и горит:( Кто что подскажет???
  10. Lomik
    Lomik Завсегдатай
    25 сен 2008
    808
    А4/В8 2.0 TDI
    У меня лючек закрывается, только тогда, когда я закрываю машину (ставлю на охрану) при выключенном двигателе и открывается, когда я ее открываю...в остальных случаях (блокировка дверей при движении или изнутри и т.д. лючек открыт) Привод лючка сдох очень быстро, через год заметил, через 2 поменял за 10 минут, пока работает
  11. kuzma_20
    kuzma_20 Участник форума
    18 май 2008
    338
    А4 B8\2.0 тди 09г.
    А я каждый раз на заправках мучаюсь по 10 раз с брелком играюсь открыть -закрыть. Уже просто бесит! Но менять холодно вдруг что-нибудь треснет.
  12. MqZqHqKq
    8 фев 2013
    1.446
    A4/B8 Avant 1.8T
    Ошибки смотрел? Похоже на катушки! Да и в профиле поправь, а то у тебя В6 11 года:)
  13. Mixail86
    Mixail86 Новичок
    6 фев 2014
    11
    А4/В8 18Т 11г.
    Не,ошибки не успел,на работу опаздывал! Вечером диагностик уже заказал;) Все поправил СПС!
  14. wilder
    wilder Живу я здесь
    10 апр 2007
    2.527
    Audi А4 2,0TDI 08г
    зачем менять раз болячка? у меня нихтарбайтенмана и фиг с ним. а то вот так в один прекрасный день заклинит в закрытом положении, вот тогда будут вам танцы. имхо конечно
  15. Pash`Ka
    Pash`Ka Завсегдатай
    15 сен 2009
    511
    A4 B8FL 1.8T 15г.
    для таких случаев немцы придумали шнурок. открыл боковинку багажника, дернул - лючок разблокировался.
    но меняется действительно минут за 10 если знать как его снимать.
  16. Mixail86
    Mixail86 Новичок
    6 фев 2014
    11
    А4/В8 18Т 11г.
    Диогност вынес вердикт, сильно устлавшая свеча 4ого цилиндра,он не работал! Сделал диагностику,все стер, теперь как новая,но сказал все свечи на замену, пробег на данный момент 49000,вот и думай теперь из за чего:(?????
  17. Sany_OK
    Sany_OK
    3 янв 2008
    2.641
    Т.е. свечи прошли 49 тыс.км.?
  18. MqZqHqKq
    8 фев 2013
    1.446
    A4/B8 Avant 1.8T
    Возможно из за катушки! Катушка горит из за свечи а свеча из за катушки. Тут все с точностью наоборот.
  19. Sany_OK
    Sany_OK
    3 янв 2008
    2.641
    Насвечник прошивать может, но если "свеча" умирает из-за катушки - под "замену" (пескоструй как вариант) катушку и свечу :)
    Скорее всего просто отработали свое свечи на нашем топливе :)
  20. wilder
    wilder Живу я здесь
    10 апр 2007
    2.527
    Audi А4 2,0TDI 08г
    поглядю как потеплеет. точно знаю, что его уже меняли "там"
