FAQ по обвесам: Audi А4 (95-...)
Тема в разделе "Тюнинг", создана пользователем YanRS, 31 янв 2005.
  1. Timon-ALF
    Timon-ALF Участник форума
    21 фев 2005
    125
    A6 C6 3.0TDI Q
    Ответ: FAQ по обвесам: Audi А4 (95-...)
    Спасибки...Прикольно сделал!
    А как??? Просто хром убрал???
    Я бы ещё и колечки убрал бы... Более грозный вид хочется... + реснички... :)
  2. Бельмондо
    Бельмондо Живу я здесь
    14 фев 2005
    1.193
    VAGоВод
    Снимал хром и красил...
  3. Entho
    Entho Bad e-mail
    2 июн 2005
    2.917
    s8.....0
    здесь подробно расписано что да как http://www.audi-club.ru/forum/showthread.php?t=29141
  4. Бельмондо
    14 фев 2005
    1.193
    VAGоВод
    и ещё более потробно, но для тех кто знает инглишь
    Removing the entire grill assembly from the hood. Raise the hood and starting at either end of the grill, squeeze the plastic clips (six in all) on the top of the grill (engine side) toward the grill while pushing the grill assembly forward. The top should tip out and lift the grill upward to release the bottom.
    Removing the grill trim from the grill. Once the grill is out, the next step is to remove the chrome trim. On the back of the grill there are 12 tabs along the top and bottom, which hold the trim ring to the body of the grill. In addition, there are two `ears' on either end, which hold the trim.
    Start at one end of the grill and unhook the two ears by pushing the trim downward and away from the grill (this is the hardest part). Once one end of the trim is free, start working your way across the grill to the other end, releasing the tabs on the top and bottom of the trim. Use a small flat-blade screwdriver to carefully pull the grill clips away from the trim tabs. This is the hardest part to explain, but it is obvious what needs to be done once you have a good look at the back of the grill.
    Prep the trim for Sanding. Once the trim is removed, wash it thoroughly with warm water and a good strong detergent (I found a toothbrush to be very helpful). You might want to wash the grill as well, just for the hell of it.
    Sanding. Some folks think this step is unnecessary and you may wish to skip this step. I don't think any primer or paint is going to stick to chrome plating, so I recommend you sand the trim. I would not use any paper coarser than #400; for fear that the sanding marks will show up under the paint. Finer than #600 may not provide enough `tooth' for the primer to stick to. The plating is very tough and will take a while to roughen up.
    Final paint prep. Inspect the trim to ensure all surfaces to be painted are thoroughly sanded. Wipe the entire trim with a clean cloth soaked in rubbing alcohol to remove all sanding residue and fingerprints/oils.
    Primer. Apply a suitable automotive primer, `filling' primer is not recommended. Filling primer is designed to fill small door dings and is too thick for this application. Make sure your primer and paint are compatible! I recommend buying the same brand of primer and paint and reading all the instructions on both cans. Apply at 70degrees or higher for best results, low humidity is also recommended for best results. I used three Very light coats.
    Painting. Allow the primer to dry as per the manufacturer's instructions. Follow manufacturer's instructions for applying the paint. I used four Very light coats. Once the paint had dried for about an hour, I moved the trim to a photographic film drying cabinet, where I was able to cure the paint at 150-degrees and very low humidity for a couple of hours. You may wish to replicate this step using whatever you have at hand.
    Reinstallation. Hook one end of the trim over the `ears' on the grill and work your way down the grill to the other end. Once the `ears' are hooked up on the other end, the grill is ready to replace. Hook the lower edge of the grill over the grill opening (from the outside of the hood) and push it into place. Ensure that all the clips are fully engaged. Close hood and admire.
  5. Бельмондо
    14 фев 2005
    1.193
    VAGоВод
    и фото :rock:
  6. Entho
    Entho Bad e-mail
    2 июн 2005
    2.917
    s8.....0
    RED RS что ты ещё успел тюнинговать .... :):)
  7. Бельмондо
    14 фев 2005
    1.193
    VAGоВод
    Бампер RS будет уже второй первый мне "Космич" снёс... Но тот был пролайн больше с ними никогда не свяжусь, теперь жду ригер...S-очная оптика, ксенон...
    Выхлоп... А так воснавном по музыке заморачиваюсь, вот сейчас строю 3 -к, фронт...
  8. Timon-ALF
    21 фев 2005
    125
    A6 C6 3.0TDI Q
    Спасибо Вам, добрые люди, за полезную инфу... :):):)
    1 человеку нравится это.
  9. Entho
    Entho Bad e-mail
    2 июн 2005
    2.917
    s8.....0
    А чё с выхлопом ...пламегасители??
  10. Бельмондо
    14 фев 2005
    1.193
    VAGоВод
    Пока да, вот теперь думаю паука на заказ сделать...
  11. eclipse
    eclipse Живу я здесь
    1 ноя 2004
    1.285
    A4 (B8) 2.0Q TFSI S-Line
    А возьмёца кто нить его делать то??? :shock: Есть приблизительные фоты как будет выглядить? Что расчитываешь от него получить?
  12. Entho
    Entho Bad e-mail
    2 июн 2005
    2.917
    s8.....0
    ты нечипован ?
    да кстати что нужно сделать шоб пламегасители поставить...или просто трубу ввентить и усё ?
    есть фоты твоего пепелаца....?
  13. Бельмондо
    14 фев 2005
    1.193
    VAGоВод
    eclipse, это пока задумки, может просто родной отпалирую.
    enthoMatrix, нет не чепован пока толку нет чиповать, вырезают кат и вместо него вваривают пламя госитель или могут сделать на основе твоего ката...
    Фото только те что на аватаре, но они уже старые им больше года.
    Мне не везёт когда машину фоткаю...всегда какаето ерунда преключается...
  14. Entho
    Entho Bad e-mail
    2 июн 2005
    2.917
    s8.....0
    в томже фк продаются готовые пламягасители в замен катов....будут фоты засвети ...
    а как прибавка чувствуется...иль куйня
    насшёт мойх вопрос...просто недавно пересел с таза на аудь....поэтому нашёт тюнинга малость растерен
    скоро права получу и реализуюсь....с твоей помощью... :beer:
  15. Бельмондо
    14 фев 2005
    1.193
    VAGоВод
    Смотря в каком состоянии у тебя каты если забитые то почувствуешь, но не так что бы она прям литела.
    А так чем смогу помогу...Обращайся...
  16. Entho
    Entho Bad e-mail
    2 июн 2005
    2.917
    s8.....0
    ПАСИБ :beer:
    а ты нулевик ставил ?
  17. Бельмондо
    14 фев 2005
    1.193
    VAGоВод
  18. Timon-ALF
    21 фев 2005
    125
    A6 C6 3.0TDI Q
    А чё за система у тебя???
  19. Бельмондо
    14 фев 2005
    1.193
    VAGоВод
    что бы не за____ть тему я решил открыть новую...
    А то тут и так уже много лишнего написано не относящегося к теме...
    http://audi-club.ru/forum/showthread.php?p=628357#post628357
  20. eclipse
    1 ноя 2004
    1.285
    СМОТРИ ОТВЕТ ТУТ дабы тут не захламлять тему.
