за последние пару дней полезли ошибки.... с чем может быть связано??? ------------------------------------------------------Tuesday,10,April,2012,18:50:38:10074 VCDS Version: Release 10.6.3 Address 01: Engine Labels: 06B-907-557-ALT.lbl Part No SW: 8E0 909 557 HW: Component: 2.0L R4/5VS 0003 Coding: 0011501 Shop #: WSC 00116 210 14986 VCID: F0EB54F39A25 3 Faults Found: 17070 - ECM Power Relay Control Circuit (J271): Short to GND P0686 - 002 - Lower Limit Exceeded - MIL ON 16514 - Oxygen (Lambda) Sensor B1 S1: Malfunction in Circuit P0130 - 004 - No Signal/Communication - MIL ON 16486 - Mass Air Flow Sensor (G70): Signal too Low P0102 - 002 - Lower Limit Exceeded - Intermittent Readiness: 0110 0101 ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 8E0-614-517.lbl 4 Faults Found: 01423 - Lateral Acceleration Sensor (G200) 27-10 - Implausible Signal - Intermittent 00526 - Brake Light Switch-F 36-10 - Open Circuit - Intermittent 18265 - Load Signal: Error Message from ECU P1857 - 35-10 - - - Intermittent 00526 - Brake Light Switch-F 27-10 - Implausible Signal - Intermittent --------------------------------------------------------------- позже..... ---------------------------------------------------------------- Wednesday,11,April,2012,14:39:21:10074 ------------------------------------------------------------------------------- Address 01: Engine Labels: 06B-907-557-ALT.lbl 3 Faults Found: 17070 - ECM Power Relay Control Circuit (J271): Short to GND P0686 - 002 - Lower Limit Exceeded - MIL ON 16514 - Oxygen (Lambda) Sensor B1 S1: Malfunction in Circuit P0130 - 004 - No Signal/Communication - MIL ON 16716 - Knock Sensor 2 (G66): Signal too Low P0332 - 002 - Lower Limit Exceeded - Intermittent Readiness: 0110 0101 ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 8E0-614-517.lbl 2 Faults Found: 00526 - Brake Light Switch-F 36-10 - Open Circuit - Intermittent 01435 - Brake Pressure Sensor 1 (G201) 35-10 - - - Intermittent ----------------------------------------------------------------------- Сегодня.... ------------------------------------------------------------------ Wednesday,11,April,2012,23:07:00:10074 -------------------------------------------------------------------------- Address 01: Engine Labels: 3 Faults Found: 17070 - ECM Power Relay Control Circuit (J271): Short to GND P0686 - 002 - Lower Limit Exceeded 16514 - Oxygen (Lambda) Sensor B1 S1: Malfunction in Circuit P0130 - 004 - No Signal/Communication 16955 - Brake Switch (F): Implausible Signal P0571 - 008 - Implausible Signal - Intermittent Address 03: ABS Brakes Labels: 8E0-614-517.lbl 2 Faults Found: 00526 - Brake Light Switch-F 36-10 - Open Circuit - Intermittent 01542 - Yaw Rate Sensor (G202) 27-10 - Implausible Signal - Intermittent ---------------------------------------------------------- то,что "лягушку" пора менять...понятно....а остальное что это??? чего тут еще ожидать??? спаибо... P.S. да,и еще,сегодня заметил какой-то странный,то ли удар,то ли что....при развороте резком....в районе правого переднего колеса....(удар однократный)
питание проверить для начала(РАЗЬЕМЫ, РЕЛЕ, ПРЕДЫ, МАССЫ) и потереть ошибки. изза этого такой букет сразу вылезти может.
