Запчасти САКС и ЛЕМФЕРДЕР для S4(4А)
Тема в разделе "Тюнинг", создана пользователем Автор, 8 авг 2006.
  1. Автор
    Автор Живу я здесь
    21 дек 2005
    3.466
    <TABLE cellSpacing=0 cellPadding=2 width="100%" border=0><TBODY><TR class=TableRow2 vAlign=top><TD class=verysmall>1</TD><TD>SACHS</TD><TD noWrap>3082 308 042
    <SMALL></SMALL></TD><TD>Clutch Pressure Plate
    </TD><TD>
    <!-- Artikel-Kriterien -->
    • Diameter [mm]: 240
    • Parameter: MF240
    </TD></TR><TR class=TableRow1 vAlign=top><TD class=verysmall>2</TD><TD>SACHS</TD><TD noWrap>1864 528 441
    <SMALL></SMALL></TD><TD>Clutch Disc
    </TD><TD>
    • Hub Profile: 21,8x24,2-23N
    • Number of Teeth: 23
    • Parameter: 240B
    </TD></TR><TR class=TableRow2 vAlign=top><TD class=verysmall>3</TD><TD>SACHS</TD><TD noWrap>3151 271 937
    <SMALL></SMALL></TD><TD>Releaser
    </TD><TD>
    • Parameter: KZIS-0
    </TD></TR><TR class=TableRow1 vAlign=top><TD class=verysmall>4</TD><TD>SACHS</TD><TD noWrap>6284 003 031
    <SMALL></SMALL></TD><TD>Master Cylinder, clutch
    </TD><TD>
    • To Chassis No. : 4A-P-038 000
    </TD></TR><TR class=TableRow2 vAlign=top><TD class=verysmall>5</TD><TD>SACHS</TD><TD noWrap>6284 003 031
    </TD><TD>
    • From Chassis No. : 4A-P-038 001
    • Driver Position : For right-hand drive vehicles
    </TD></TR><TR class=TableRow1 vAlign=top><TD class=verysmall>6</TD><TD>SACHS</TD><TD noWrap>6284 004 031
    </TD><TD>
    • Driver Position : For left-hand drive vehicles
    </TD></TR><TR class=TableRow2 vAlign=top><TD class=verysmall>7</TD><TD>SACHS</TD><TD noWrap>6283 001 031
    <SMALL></SMALL></TD><TD>Slave Cylinder, clutch
    </TD><TD>
    </TD></TR><TR class=TableRow1 vAlign=top><TD class=verysmall>8</TD><TD>SACHS</TD><TD noWrap>2100 078 031
    <SMALL></SMALL></TD><TD>Clutch, radiator fan
    </TD><TD>
    • Parameter: VL100L
    </TD></TR><TR class=TableRow2 vAlign=top><TD class=verysmall>9</TD><TD>SACHS</TD><TD noWrap>115 476
    <SMALL></SMALL></TD><TD>Shock Absorber
    Advantage</TD><TD>
    • Fitting Position : Front Axle
    • Suspension : for vehicles with standard chassis
    • Labour [h] : 0,70
    • Shock Absorber Type: Gas Pressure
    • Shock Absorber Design: Suspension Strut Insert
    • Shock Absorber System: Twin-Tube
    </TD></TR><TR class=TableRow1 vAlign=top><TD class=verysmall>10</TD><TD>SACHS</TD><TD noWrap>802 198
    <SMALL></SMALL></TD><TD>Suspension Strut Support Bearing
    </TD><TD>
    • From Chassis No. : 4A-N-040000
    • Fitting Position : Front Axle, Both Sides
    • Quantity per Axle: 2
    • Alternative Repair Kit: 802 245
    </TD></TR><TR class=TableRow2 vAlign=top><TD class=verysmall>11</TD><TD>SACHS</TD><TD noWrap>801 030
    <SMALL></SMALL></TD><TD>Friction Bearing, suspension strut support mounting
    </TD><TD>
    </TD></TR><TR class=TableRow1 vAlign=top><TD class=verysmall>12</TD><TD>SACHS</TD><TD noWrap>802 245
    <SMALL></SMALL></TD><TD>Repair Kit, suspension strut
    </TD><TD>
    </TD></TR><TR class=TableRow2 vAlign=top><TD class=verysmall>13</TD><TD>SACHS</TD><TD noWrap>900 013
    <SMALL></SMALL></TD><TD>Dust Cover Kit, shock absorber
    SERVICE KIT</TD><TD>
    </TD></TR><TR class=TableRow1 vAlign=top><TD class=verysmall>14</TD><TD>SACHS</TD><TD noWrap>170 141
    Advantage</TD><TD>
    • Fitting Position : Rear Axle
    • Labour [h] : 1,10
    • Shock Absorber Mounting Type: Top pin, Bottom eye
    </TD></TR><TR class=TableRow2 vAlign=top><TD class=verysmall>15</TD><TD>LEMFÖRDER</TD><TD noWrap>020 390 170 504
    [​IMG]<SMALL>No longer available</SMALL> </TD><TD>Tie Rod, steering
    </TD><TD>
    • Fitting Position : Outer
    • To Chassis No. : 4A0-P-001983
    • Fitting Position: Front Axle, Left
    • Length [mm]: 619
    • Cone Size [mm]: 14
    • Pipe Ø [mm]: 22
    </TD></TR><TR class=TableRow1 vAlign=top><TD class=verysmall>16</TD><TD>LEMFÖRDER</TD><TD noWrap>020 390 171 504
    </TD><TD>
    • Fitting Position: Front Axle, Right
    • Length [mm]: 619
    • Pipe Ø [mm]: 22
    </TD></TR><TR class=TableRow2 vAlign=top><TD class=verysmall>17</TD><TD>LEMFÖRDER</TD><TD noWrap>10022
    <SMALL></SMALL></TD><TD>Tie Rod, steering
    </TD><TD>
    • From Chassis No. : 4A-P-001984
    • Length [mm]: 619
    • Pipe Ø [mm]: 22
    </TD></TR><TR class=TableRow1 vAlign=top><TD class=verysmall>18</TD><TD>LEMFÖRDER</TD><TD noWrap>10023
    </TD><TD>
    • Length [mm]: 619
    • Pipe Ø [mm]: 22
    </TD></TR><TR class=TableRow2 vAlign=top><TD class=verysmall>19</TD><TD>LEMFÖRDER</TD><TD noWrap>22050
    </TD><TD>
    </TD></TR><TR class=TableRow1 vAlign=top><TD class=verysmall>20</TD><TD>LEMFÖRDER</TD><TD noWrap>12407
    [​IMG]<SMALL>No longer available</SMALL> </TD><TD>Releaser
    </TD></TR></TBODY></TABLE>
