Сделал диагностику , не могу расшифровать коды!
Тема в разделе "4B C5", создана пользователем Alex_1111, 5 дек 2013.
  1. Alex_1111
    Alex_1111 Участник форума
    9 авг 2013
    127
    A6/c6/4f 3.2 2006г
    Wednesday,04,December,2013,18:11:29:37412
    VCDS Version: Release 11.11.0
    Data version: 20111111
    Chassis Type: 4B - Audi A6 C5
    Scan: 01 02 03 06 08 15 16 17 18 22 34 35 36 37 45 55 56 57 65 67
    75 76 77
    VIN: WAUZZZ4FX5N094329 Mileage: 157530km/97884miles
    Address 01: Engine Labels: Redir Fail!
    Part No SW: 4F0 910 401 L HW: 4F0 907 401 A
    Component: 3.0L V6TDI G000AG 0040
    Revision: --H01--- Serial number:
    Coding: 0011772
    Shop #: WSC 02334 785 00200
    VCID: 254B8030ECFA196
    7 Faults Found:
    17058 - Cylinder 4 Glow Plug Circuit (Q13)
    P0674 - 001 - Electrical Fault
    Freeze Frame:
    RPM: 0 /min
    Torque: 253.5 Nm
    Speed: 0.0 km/h
    Duty Cycle: 1.0 %
    Voltage: 11.32 V
    Duty Cycle: 15.0 %
    Temperature: 11.7°C
    Bin. Bits: 00110000
    16785 - EGR System
    P0401 - 002 - Insufficient Flow - Intermittent
    Freeze Frame:
    RPM: 1890 /min
    Torque: 218.4 Nm
    Speed: 104.2 km/h
    Duty Cycle: 48.8 %
    Duty Cycle: 20.9 %
    Mass Air / Rev.: 569.9 mg/str
    Duty Cycle: 55.6 %
    Mass Air / Rev.: 399.5 mg/str
    19804 - Control Circuit for Controller for Turbocharger 1 (J724)
    P3348 - 008 - Electrical Malfunction - Intermittent
    Freeze Frame:
    RPM: 0 /min
    Torque: 167.7 Nm
    Speed: 0.0 km/h
    Duty Cycle: 1.0 %
    Voltage: 12.31 V
    Bin. Bits: 00101100
    Absolute Pres.: 999.6 mbar
    Absolute Pres.: 1009.8 mbar
    29696 - No Communication with Comfort System Control Module (J393)
    U1000 - 001 - - Intermittent
    Freeze Frame:
    RPM: 0 /min
    Torque: 249.6 Nm
    Speed: 0.0 km/h
    Duty Cycle: 1.0 %
    Voltage: 11.25 V
    Bin. Bits: 00101100
    Torque: 93.6 Nm
    Temperature: 11.7°C
    16488 - Mass Air Flow Sensor (G70)
    P0104 - 001 - Intermittent - Intermittent
    Freeze Frame:
    RPM: 0 /min
    Torque: 249.6 Nm
    Speed: 0.0 km/h
    Duty Cycle: 80.9 %
    Voltage: 12.01 V
    Mass Air / Rev.: 0.0 mg/str
    Temperature: 10.8°C
    18348 - Powertrain Databus
    P1940 - 001 - Missing Message from Control Module for Battery Monitoring - Intermittent
    Freeze Frame:
    RPM: 0 /min
    Torque: 222.3 Nm
    Speed: 0.0 km/h
    Duty Cycle: 1.0 %
    Voltage: 11.32 V
    (no units): 0.0
    Temperature: 18.0°C
    18061 - Please check DTC Memory of ABS Controller
    P1653 - 002 - - Intermittent
    Freeze Frame:
    RPM: 0 /min
    Torque: 222.3 Nm
    Speed: 0.0 km/h
    Duty Cycle: 1.0 %
    Voltage: 11.70 V
    Bin. Bits: 00101100
    Torque: 93.6 Nm
    Temperature: 18.0°C
    Readiness: 0 2 0 0 0
    Address 02: Auto Trans Labels: 09L-927-760.lbl
    Part No SW: 4F0 910 156 H HW: 09L 927 156
    Component: AG6 09L 3.0lTDI RdW 0100
    Revision: --H01--- Serial number: 0091371
    Coding: 0000001
    Shop #: WSC 02325 785 00200
    VCID: 285589049BE804E
    1 Fault Found:
    18265 - Load Signal
    P1857 - 000 - Error Message from ECU - Intermittent
    Freeze Frame:
    Fault Status: 00110000
    Fault Priority: 0
    Fault Frequency: 4
    Reset counter: 40
    Mileage: 156689 km
    Time Indication: 0
    Date: 2013.10.31
    Time: 12:29:53
    Freeze Frame:
    RPM: 0 /min
    RPM: 0 /min
    RPM: 0 /min
    (no units): 30.0
    (no units): 25.0
    Temperature: 14.0°C
    T.B. Angle: 0.0°
    Address 03: ABS Brakes Labels: 4F0-910-517.lbl
    Part No SW: 4F0 910 517 L HW: 4F0 614 517 L
    Component: ESP 8.0 quattro H03 0090
    Revision: 00000000 Serial number: 00000000000000
    Coding: 0004488
    VCID: 2D5B7810B40A216
    1 Fault Found:
    18265 - Load Signal
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 3
    Fault Frequency: 4
    Reset counter: 171
    Mileage: 156689 km
    Time Indication: 0
    Date: 2013.10.31
    Time: 12:29:55
    Freeze Frame:
    Hex Value: 0x00C0
    Hex Value: 0x2282
    Hex Value: 0x0028
    Hex Value: 0x018E
    Hex Value: 0x00FF
    Address 08: Auto HVAC Labels: 4F0-910-043.lbl
    Part No SW: 4F0 910 043 HW: 4F1 820 043 J
    Component: KLIMABETAETIGUNGH11 0150
    Revision: 00000025 Serial number: 00000000105697
    Coding: 0002070
    VCID: DBBF66C81A3E1F6
    4 Faults Found:
    00657 - Positioning Motor for Central Vents (V102)
    003 - Mechanical Failure - Intermittent
    Freeze Frame:
    Fault Status: 00100011
    Fault Priority: 3
    Fault Frequency: 171
    Reset counter: 192
    Mileage: 155147 km
    Time Indication: 0
    Date: 2013.09.03
    Time: 14:39:10
    Freeze Frame:
    Voltage: 13.50 V
    Temperature: 22.0°C
    (no units): 86.0
    (no units): 38.0
    Temperature: 24.0°C
    00739 - Coolant Circulation Pump (V50)
    002 - Lower Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Status: 00100010
    Fault Priority: 3
    Fault Frequency: 166
    Reset counter: 198
    Mileage: 155147 km
    Time Indication: 0
    Date: 2013.09.03
    Time: 14:39:18
    Freeze Frame:
    Temperature: 64.0°C
    00458 - Control Module for Battery Monitoring (J367)
    004 - No Signal/Communication - Intermittent
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 171
    Mileage: 156689 km
    Time Indication: 0
    Date: 2013.10.31
    Time: 12:30:16
    Freeze Frame:
    ON
    Bin. Bits: 00001111
    00796 - Fan for Interior Temp Sensor (V42)
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 197
    Mileage: 157500 km
    Time Indication: 0
    Date: 2013.11.30
    Time: 11:12:09
    Freeze Frame:
    Voltage: 13.30 V
    Temperature: 1.0°C
    Address 15: Airbags Labels: 4F0-910-655-8R.lbl
    Part No SW: 4F0 910 655 D HW: 4F0 959 655 B
    Component: 33 AIRBAG AUDI8RH29 0250
    Revision: 05H29000 Serial number: 0037LD0576AT
    Coding: 0013107
    Shop #: WSC 35882 143 50700
    No fault code found.
    Address 16: Steering wheel Labels: 4F0-910-549.lbl
    Part No SW: 4F0 910 549 HW: 4F0 953 549 A
    Component: Lenksдulenmodul H07 0230
    Revision: 00H07000 Serial number: 90022050150338
    Coding: 0002041
    Shop #: WSC 02323 785 00200
    VCID: E6C9473CD17C52E
    Part No: XXXXXXXXXXX
    Component: Lenkradmodul H06 0080
    1 Fault Found:
    02072 - Control Module for Energy Management (J644)
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 2
    Reset counter: 171
    Mileage: 156684 km
    Time Indication: 0
    Date: 2013.10.30
    Time: 18:27:26
    Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
    Part No SW: 4F0 910 900 A HW: 4F0 920 900 S
    Component: KOMBIINSTR. M73 H10 0630
    Revision: 00200000 Serial number: 4R733NC15
    Coding: 0001003
    Shop #: WSC 50741 143 61874
    VCID: 1E39AFDCC9ACCAE
    Address 18: Aux. Heat Labels: None
    Part No SW: 4F0 910 105 D HW: 4F0 265 081 H
    Component: Heizgeraet H01 0050
    Revision: A Serial number: 09011480
    Coding: 0000111
    2 Faults Found:
    01330 - Central Control Module for Central Convenience (J393)
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 182
    Mileage: 156595 km
    Time Indication: 0
    Date: 2013.10.10
    Time: 11:27:38
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 182
    Mileage: 156689 km
    Time Indication: 0
    Date: 2013.10.31
    Time: 12:29:58
    Freeze Frame:
    OFF
    Temperature: 7.0°C
    Temperature: 19.0°C
    Address 37: Navigation Labels: 4E0-910-88x-37.lbl
    Part No SW: 4E0 910 888 Q HW: 4E0 919 887 C
    Component: MNS ECE H44 2050
    Revision: 00000000 Serial number: 305AO057565708
    Shop #: WSC 00435 935 89793
    VCID: 3C7D45547F70B8E
    Address 55: Xenon Range Labels: 8P0-907-357.lbl
    Part No: 8P0 907 357 H
    Component: Dynamische LWR H01 0010
    Revision: 00000001 Serial number:
    Coding: 0000003
    Shop #: WSC 21102 142 06654
    VCID: 3F8732586E66A36
    Address 56: Radio Labels: 4E0-910-541.lbl
    Part No SW: 4E0 910 541 Q HW: 4F0 035 541
    Component: TUNER EU/US/RDW H41 0620
    Revision: 00000000 Serial number: 352AL057588320
    Coding: 0000001
    VCID: 2E597F1CB90C5AE
    Address 76: Park Assist Labels: 4Fx-910-283.lbl
    Part No SW: 4F0 910 283 A HW: 4F0 919 283 A
    Component: Parkhilfe 8-Kan H12 0030
    Revision: --.--.-- Serial number: 11820501502265
    Coding: 0011006
    VCID: 22419B2CFDD4EEE
    2 Faults Found:
    01628 - Sensor for Parking-Aid; Front Mid-Left (G254)
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 14
    Reset counter: 197
    Mileage: 155166 km
    Time Indication: 0
    Date: 2013.09.03
    Time: 19:51:42
    01627 - Sensor for Parking-Aid; Front Mid-Right (G253)
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 3
    Reset counter: 192
    Mileage: 157385 km
    Time Indication: 0
    Date: 2013.11.26
    Time: 07:54:03
    Address 77: Telephone Labels: 4E0-910-336.lbl
    Part No SW: 4E0 910 336 K HW: 4E0 862 335
    Component: Handyvorb2 H10 0950
    Revision: 00000000 Serial number: 00000007537013
    Coding: 0010900
    Shop #: WSC 02335 785 00200
    VCID: 2A51730C85E436E
    End ---------------------------------------------------------------------
    помогите пожалуйста!) мне найти надо блок или что с ним связанно правая фара задняя , почему отказала!!
  2. mars_r
    mars_r Живу я здесь
    16 янв 2013
    2.067
    A6/C5 2.4, ALF 97г
