R8 v12TDI
Тема в разделе "R8", создана пользователем Chybaiss, 4 янв 2008.
  1. Chybaiss
    Chybaiss Живу я здесь
    4 июл 2004
    1.408
    Новайа читверька 2.0 с мультиГам, би-ксенией и фсякай другой ирундой)))
    Diesel prowess
    Embargoes are like rules, they are meant to be broken. This time around Auto Motor und Sport in Germany have sent out their January issue to subscribers featuring a rendering of an Audi R8 Concept with V12 TDI engine article. The story is still under wraps by Audi until January 13 when it will make its world wide debut at the 2008 NAIAS in Detroit.
    AMS calls the Audi R8 V12 TDI a study model, but depending on feedback the car might just make it to mass production (hand built mass production that is). The V12 TDI engine has made quite a name for itself on the track in the R10 race car and will be featured in the upcoming Q7 V12 TDI. It is a proven engine and will obviously not burn your R8 to a crisp.
    Some numbers from the article. The Audi R8 V12 TDI produces 500 hp with 1,000 Nm of torque, 0 – 100 km/h in just 4.2 seconds, top speed lies over 300 km/h and fuel consumption is rated at 10 liters per 100 km. Disadvantage of the V12 TDI over the V8 is that the little trunk space is entirely gone due to the V12 size and it weighs 100 kg more too.
    The front fascia is altered on the R8 V12 TDI because the engine requires more cooling, which is achieved through the larger airducts.
    Thank you Thomas for the tip! More images at R8-quattro forum.
    (c) Worldcarfans.com
  2. N&M
    N&M Живу я здесь
    22 янв 2007
    3.155
    Smoby Voyager
    Ответ: R8 v12TDI
    видать, не удалось им сделать бензиновый мотор пожаробезопасным
  3. AMP
    AMP Модератор
    1 янв 2007
    81.410
    BMW
    Ответ: R8 v12TDI
    ну как "study" можно было и W16 квадротурбо от вейрона запихнуть.
  4. Dmitrij1
    Dmitrij1 Bad e-mail
    20 дек 2007
    29
    Audi S6 06г. 5.2 FSI Quattro
    Ответ: R8 v12TDI
    Мда, зачётный агрегат. Интересно, сколько весит этот дизельный монстр? Ведь его врядли сделали из аллюминия.
  5. Thoomas
    Thoomas Участник форума
    6 сен 2005
    428
    Audi A5 2.0D 2019
    Ответ: R8 v12TDI
    Угу, из-за веса силового агрегата сделали из пластика. С приводом на одно колесо.
  6. Entho
    Entho Bad e-mail
    2 июн 2005
    2.917
    s8.....0
  7. Entho
    Entho Bad e-mail
    2 июн 2005
    2.917
    s8.....0
    Ответ: R8 v12TDI
    1 человеку нравится это.
  8. Baxxter
    Baxxter Живу я здесь
    14 апр 2007
    2.203
    Q5
    Ответ: R8 v12TDI
    красава :)
  9. Nenad
    Nenad Bad e-mail
    7 янв 2005
    1.447
    A6 4G,3.0TFSI
    Ответ: R8 v12TDI
    [​IMG][​IMG]
    [​IMG][​IMG]
    [​IMG][​IMG]
  10. AMP
    AMP Модератор
    1 янв 2007
    81.410
    BMW
    Ответ: R8 v12TDI
    Эт как же надо быть неуверенными в продажах Ку7 шоп такое бабло вливать в пустые концепты?
  11. testa
    testa Миша quattro
    20 янв 2006
    3.921
    Audi A3 8V
    Ответ: R8 v12TDI
    Охереннейший концепт от Ауди за последние несколько лет. А может десятков. Очень красивая, сволочь...
  12. Driple
    Driple Новичок
    6 фев 2007
    13
    Audi 100/ 2.0 86г.
  13. Vl@d S4
    Vl@d S4 quattro ®
    18 окт 2006
    8.537
    Porsche Macan Turbo
    Ответ: R8 v12TDI
    Внушительный монстр :)
  14. Lynx
    Lynx Живу я здесь
    31 май 2007
    4.314
    субара
  15. Baxxter
    14 апр 2007
    2.203
    Q5
    Ответ: R8 v12TDI
    Audi отказалась от дизеля V12 :(
    На недавно прошедшем автосалоне в Женеве Audi представила уникальное и очень красивое купе Audi R8 V12 TDI, которое было оснащено дизельным двигателем V12 объемом 6,0 л. Агрегат V12 выдает аж 500 л.с. и ровно 1000 Нм! Для дизеля просто потрясающие характеристики. Причем, в Женеве представители Audi намекали на то, что они могут уже в этом году начать выпускать подобный автомобиль. Но сейчас стало известно, что от производства Audi R8 V12 TDI решено отказаться. С чем это связано сказать сложно. Видимо, в Audi решили, что двигатель V12 слишком тяжелый для R8, что отрицательно сказывается на управляемости. Но дизельное купе от Audi, судя по всему, все-таки появится. Поэтому скоро немцы начнут делать R8 с дизелем V8 объемом 4,2 л. Этот мотор, конечно, гораздо скромнее V12, но и его 326 л.с. хватит легкому купе.
    // auto.mail.ru
  16. Entho
    Entho Bad e-mail
    2 июн 2005
    2.917
    s8.....0
    Ответ: R8 v12TDI
    интересная логика..сначал нарисовать, построить, представить, разрекламировать..потом подумать...и понять что оно рулитсо небудет...
