Почитали мне ошибки, ибо пару раз после мойки загорелся джеки чан. Вот что выдало: По двигателю: Address 01: Engine Labels: Redir Fail! Control Module Part Number: 4F2 910 402 D HW: 4F0 907 401 B Component and/or Version: 2.7L V6TDI G000AG 0010 Software Coding: 0011372 Work Shop Code: WSC 02334 785 00200 3 Faults Found: 005659 - Glowplug for Cylinder 2 (Q11): Open Circuit P161B - 001 - Upper Limit Exceeded Freeze Frame: Fault Status: 01110001 Fault Priority: 0 Fault Frequency: 1 Mileage: 163348 km Time Indication: 0 Date: 2011.05.17 Time: 23:39:55 Freeze Frame: RPM: 777 /min Torque: 101.4 Nm Speed: 0.0 km/h Duty Cycle: 1.0 % Voltage: 13.38 V Duty Cycle: 22.9 % Temperature: 63.9°C 005662 - Glowplug for Cylinder 5 (Q15): Open Circuit P161E - 001 - Upper Limit Exceeded Freeze Frame: Fault Status: 01110001 Fault Priority: 0 Fault Frequency: 1 Mileage: 186425 km Time Indication: 0 Date: 2011.10.04 Time: 06:28:09 Freeze Frame: RPM: 882 /min Torque: 93.6 Nm Speed: 0.0 km/h Duty Cycle: 1.0 % Voltage: 13.45 V Duty Cycle: 23.3 % Temperature: 15.3°C 004120 - Intake Manifold Runner (Bank 2): Lower limit not reached P1018 - 001 - Upper Limit Exceeded Freeze Frame: Fault Status: 01100001 Fault Priority: 0 Fault Frequency: 42 Mileage: 193226 km Time Indication: 0 Date: 2011.12.17 Time: 17:36:34 Freeze Frame: RPM: 0 /min Torque: 0.0 Nm Speed: 0.0 km/h Voltage: 11.55 V Duty Cycle: 20.5 % Duty Cycle: 88.8 % Duty Cycle: 20.5 % Ошибка 4120 после обнуления вылезла еще раз. Первые две обнулились и не показывались больше. Что это за ошибки? Первые две, я так понимаю последствия мойки, а вот третья? Address 76: Park Assist Labels: 4Fx-910-283.lbl Control Module Part Number: 4F0 910 283 C HW: 4F0 919 283 C Component and/or Version: Parkhilfe 8-Kan H12 0030 Software Coding: 0201006 Work Shop Code: WSC 131071 1023 2097151 1 Fault Found: 01545 - Sensor for Parking Aid; Rear Left (G203) 009 - Open or Short to Ground Freeze Frame: Fault Status: 01101001 Fault Priority: 3 Fault Frequency: 43 Reset counter: 169 Mileage: 189353 km Time Indication: 0 Date: 2011.10.25 Time: 11:06:07 Ошибка парктроника, как я понял проблема с задним левым? Проводку смотреть нужно? Спасибо всем, кто откликнется..
Ошибка 4120 - привет основной проблеме с дизелем, Впускной коллектор. Парктроник, ошибка не постоянная, скорее всего действительно контакт в бампере.
Я конечно их гляну, но данная проблема возникла после мойки. Вода попала на двигатель. Может просто от влажности, но галочку на сей факт поставлю. Спасибо.
http://www.audi-club.ru/forum/showthread.php?t=256709&highlight=Intake+Manifold+Runner http://www.audi-club.ru/forum/showthread.php?t=195333&highlight=Intake+Manifold+Runner
Вот и я о том.. Ща свечки поменяю, приводные ремни, жижу гидроусилителя, свежие ксеноновые + белые ходовые, ремонт проводки датчика парковки, раскидаю салон спереди и под карбон обтяжка центральной консоли. Вот как-то так. Джеки чан больше не вылезал после сброса ошибок. Визуально на коллекторе те самые приводные косточки, которые спрыгивают, стоят на месте, приводы работают. Пока подожду с коллектором. На будущее, номерок на мой BSG по новым коллекторам не подскажешь? А то я столько номеров нашел по сайту, что запутался в них.
теперь 059 963 319 J актуальный номер для свечи? насколько я понимаю под этим номером будет свеча BERU GE115. разница в цене в 2 раза.
