A4 B8 Помогите по ошибкам
Тема в разделе "A4", создана пользователем liar, 26 ноя 2014.
  1. liar
    liar Новичок
    9 дек 2010
    34
    А4/B8 2.0Q 2011
    Что бы это могло быть?
    Wednesday,26,November,2014,09:57:34:62939
    VCDS Version: Release 12.12.0
    Address 01: Engine Labels: None
    Control Module Part Number: 8N2 907 110 P HW: 8N2 907 110 D
    Component and/or Version: 2+0l R4/1V TF H25 0059
    Software Coding: 0101000C240F0160
    Work Shop Code: WSC 06324 000 00160
    ASAM Dataset: ES_ECM20QFS8K2957115P A51011 (AU48)
    VCID: 3A7BD463BDAA42CE9A7-806F
    No ASAM data for: "ES_ECM20QFS8K2957115P" (AU48)
    22 Faults Found:
    5978 - ROD - Unknown Error Code
    - 00 [032]
    Intermittent - Not Confirmed - Tested Since Memory Clear
    4699 - ROD - Unknown Error Code
    - 00 [032]
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 0
    Fault Frequency: 18
    Reset counter: 32
    Mileage: 332207 km
    Date: 2004.08.00
    Time: 02:20:00
    332207 - ROD - Unknown Error Code
    - 00 [032]
    4608 - ROD - Unknown Error Code
    - 00 [037]
    5390 - ROD - Unknown Error Code
    - 00 [032]
    7897 - ROD - Unknown Error Code
    - 00 [032]
    4635 - ROD - Unknown Error Code
    - 00 [032]
    5251 - ROD - Unknown Error Code
    - 00 [032]
    9491 - ROD - Unknown Error Code
    - 00 [032]
    330350 - ROD - Unknown Error Code
    - 00 [096]
    2674 - ROD - Unknown Error Code
    - 00 [101]
    2697 - ROD - Unknown Error Code
    - 00 [032]
    2734 - ROD - Unknown Error Code
    - 00 [032]
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 18
    Reset counter: 32
    Mileage: 332207 km
    Date: 2004.08.00
    Time: 02:20:00
    0000 - End of output
    - 00 [000]
    - 00 [096]
    2979 - ROD - Unknown Error Code
    - 00 [032]
    335360 - ROD - Unknown Error Code
    - 00 [000]
    - 00 [000]
    4063 - ROD - Unknown Error Code
    - 00 [096]
    4054 - ROD - Unknown Error Code
    - 00 [096]
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 18
    Reset counter: 32
    Mileage: 332207 km
    Date: 2004.08.00
    Time: 02:20:00
    - 00 [000]
    - 00 [032]
    Readiness: 0000 0101
  2. AlexMone
    AlexMone Живу я здесь
    1 ноя 2012
    1.532
    А4/B7 1,9 BRB 07
    #2 AlexMone, 26 ноя 2014
    ЭБУ двигателя видимо накрылось медным тазом(((
    Как себя машина ведет?
    а может глюк какой, потрите и заново проведите опрос
