Зимой из-за морозов (и, похоже, подсевшего аккумулятора) заклинило тормозные колодки и в блоке управления электромеханическим стояночным тормозом было 6 нехороших ошибок. Спойлер ------------------------------------------------------------------------------- Address 53: Parking Brake (J540) Labels: 8K0-907-801.clb Part No SW: 8K0 907 801 C HW: 8K0 907 801 C Component: EPB Audi B8 H03 0040 Revision: 00000003 Serial number: 00000000061168 Coding: Shop #: WSC 00000 000 00000 6 Faults Found: 02435 - Supply Voltage for Control Module for Right Channel 009 - Open or Short to Ground - Intermittent Freeze Frame: Fault Status: 00101001 Fault Priority: 1 Fault Frequency: 1 Reset counter: 110 Mileage: 72598 km Time Indication: 0 Date: 2012.02.05 Time: 17:43:46 Freeze Frame: Voltage: 12.80 V Count: 15 Speed: 0.0 km/h Hex Value: 0x0177 Hex Value: 0x0008 Hex Value: 0x1010 16365 - Control Module - Electrical Error; CPU 2 008 - Implausible Signal - MIL ON Freeze Frame: Fault Status: 11101000 Fault Priority: 1 Fault Frequency: 18 Reset counter: 110 Mileage: 72598 km Time Indication: 0 Date: 2012.02.05 Time: 11:47:33 Freeze Frame: Voltage: 11.40 V Count: 35 Speed: 0.0 km/h Hex Value: 0x0277 Hex Value: 0x0001 Hex Value: 0x1010 16377 - Control Module; Unspecified Internal Error 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 1 Fault Frequency: 1 Reset counter: 150 Mileage: 1048574 km Time Indication: 0 Date: 2012.02.05 Time: 11:47:32 Freeze Frame: Voltage: 11.30 V Count: 34 Speed: 0.0 km/h Hex Value: 0x0277 Hex Value: 0x0001 Hex Value: 0x1010 16377 - Control Module; Unspecified Internal Error 014 - Defective - MIL ON Freeze Frame: Fault Status: 11101110 Fault Priority: 1 Fault Frequency: 1 Reset counter: 110 Mileage: 1048574 km Time Indication: 0 Date: 2012.02.05 Time: 11:47:32 Freeze Frame: Voltage: 11.10 V Count: 53 - Hex Value: 0x4063 Hex Value: 0x0081 Hex Value: 0x1010 02432 - Supply Voltage for Left Parking Brake Motor (V282) 012 - Electrical Fault in Circuit - Intermittent Freeze Frame: Fault Status: 00101100 Fault Priority: 1 Fault Frequency: 2 Reset counter: 138 Mileage: 71710 km Time Indication: 0 Date: 2012.01.08 Time: 18:34:56 Freeze Frame: Voltage: 12.90 V Count: 12 Speed: 0.0 km/h Hex Value: 0x02E1 Hex Value: 0x0021 Hex Value: 0x0108 02432 - Supply Voltage for Left Parking Brake Motor (V282) 006 - Short to Plus - Intermittent Freeze Frame: Fault Status: 00100110 Fault Priority: 1 Fault Frequency: 1 Reset counter: 137 Mileage: 71710 km Time Indication: 0 Date: 2012.01.08 Time: 18:34:25 Freeze Frame: Voltage: 14.60 V Count: 30 Speed: 0.0 km/h Hex Value: 0x02E0 Hex Value: 0x0001 Hex Value: 0x0101 ------------------------------------------------------------------------------- Предохранители идущие на блок я снял и ездил пока без него. Вчера предохранители поставил обратно, ошибки все потёр и заново прогнал тест. Осталась одна ошибка. Спойлер ------------------------------------------------------------------------------- Address 53: Parking Brake (J540) Labels: 8K0-907-801.clb Part No SW: 8K0 907 801 C HW: 8K0 907 801 C Component: EPB Audi B8 H03 0040 Revision: 00000003 Serial number: 00000000061168 Coding: Shop #: WSC 00000 000 00000 1 Fault Found: 16377 - Control Module; Unspecified Internal Error 014 - Defective - MIL ON Freeze Frame: Fault Status: 11101110 Fault Priority: 1 Fault Frequency: 1 Reset counter: 110 Mileage: 1048574 km Time Indication: 0 Date: 2012.02.05 Time: 11:47:32 Freeze Frame: Voltage: 11.10 V Count: 53 - Hex Value: 0x4063 Hex Value: 0x0081 Hex Value: 0x1010 ------------------------------------------------------------------------------- На табло как горел так и горит Parking brake malfunction. Предохранители пока снова снял. Вопрос: если ошибок стало меньше, то реально ли блок оживить? Может у него или у другого блока в памяти осталось что блок управления стояночным тормозом дефектный? Можно ему как-то эту память очистить (сделать резет) или однозначно менять?
Да нет у них никаких рисетов, кроме клеммы 30. Похоже помочь сможет только обновление ПО, но я не скажу есть ли оно такое. Километраж в ошибке красивый!
Я не совсем в теме про клемму 30. Это тоже самое что отсоединить аккумулятор? Можно подробнее? До этого питание на блок у меня вообще не приходило, были сняты предохранители. В этом случае это тоже самое что отсоединенный аккумулятор? В данный момент я этот блок вообще из машины вытащил, на столе валяется... Думал можно внутрь заглянуть, а он какой то не разборный Что с ним делать, обратно ставить и пробовать "клемму 30"? Что она поможет обнулить? ПыСЫ Да, километраж аццкий, я тоже заметил...
Нет, не оживил. Пластмассовый корпус запаен так, что если захочешь заглянуть внутрь, то только пилить его. Купил на эбэй недорого такой же б/у и просто свой вытащил, а этот поставил. Встал как родной и даже со шнурком не надо было шаманить. На всё ушло минут 5.
