Добрый день. Проблема с двигателем 1,9 TDI. после грозы с большим дождем не запускается. не запускается с помощью стартера. только веревкой. потери холостого хода. после шторма, сам, начал действовать вентилятор кондиционера.
Sunday,14,July,2013,12:49:26:11239 VCDS Version: Release 11.11.6 Data version: 20121223 -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 8E - Audi A4 B6/B7 Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67 69 75 76 77 VIN: WAUZZZ8E Mileage: 199440km/123926miles ------------------------------------------------------------------------------- Address 01: Engine Labels: 038-906-019-AVF.lbl Part No: 038 906 019 JT Component: 1,9l R4 EDC 0000SG 1572 Coding: 00003 Shop #: WSC 00011 VCID: 72E0679A3E84C68826F WAUZZZ8E AUZ6Z0B0245849 5 Faults Found: 17978 - Engine Start Blocked by Immobilizer P1570 - 35-10 - - Intermittent 18009 - Relay for Supply Voltage Terminal 30 (J317) P1601 - 35-00 - Implausible Signal 18080 - Coolant Fan Control 1 P1672 - 35-10 - Open or Short to Ground - Intermittent 18008 - Power Supply Terminal 15 P1600 - 35-10 - Voltage too Low - Intermittent 18061 - Please check DTC Memory of ABS Controller P1653 - 35-00 - Readiness: 0 0 X X X ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 8E0-614-517.lbl Part No: 8E0 614 517 A Component: ABS/ESP allrad 1726 Coding: 04255 Shop #: WSC 06435 VCID: 26484BCAC2CCEA287A7 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 8E0-820-043.lbl Part No: 8E0 820 043 H Component: A4 Klimaautomat 1016 Coding: 00000 Shop #: WSC 63351 VCID: 26484BCAC2CCEA287A7 7 Faults Found: 01809 - Actuating Motor for Temperature Flap; Left (V158) 41-10 - Blocked or No Voltage - Intermittent 01841 - Potentiometer/Actuator for Temperature Flap; Left (G220) 30-10 - Open or Short to Plus - Intermittent 01810 - Actuating Motor for Temperature Flap; Right (V159) 41-10 - Blocked or No Voltage - Intermittent 01842 - Potentiometer/Actuator for Temperature Flap; Right (G221) 30-10 - Open or Short to Plus - Intermittent 00604 - Potentiometer Positioning Motor for Air Flow Flap (G113) 30-10 - Open or Short to Plus - Intermittent 00716 - Air recirculation Flap Positioning Motor (V113) 41-10 - Blocked or No Voltage - Intermittent 00532 - Supply Voltage B+ 53-10 - Supply Voltage Too Low - Intermittent ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl Part No: 8E0 907 279 E Component: int. Lastmodul RDW 0305 Coding: 00001 Shop #: WSC 63351 VCID: 346CA182041088B8F43 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags Labels: 8E0-959-655-84.lbl Part No: 8E0 959 655 B Component: Airbag 8.4EP 2000 Coding: 0010602 Shop #: WSC 63351 000 00000 VCID: 36689B8A426C9AA8CA7 2 Faults Found: 01217 - Side Airbag Igniter; Driver Side (N199) 001 - Upper Limit Exceeded - Intermittent - MIL ON 01217 - Side Airbag Igniter; Driver Side (N199) 002 - Lower Limit Exceeded - MIL ON ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 8E0-953-549.lbl Part No: 8E0 953 549 F Component: Lenksįulenmodul 0308 Coding: 00012 Shop #: WSC 63351 VCID: 36689B8A126C9AA8CA7 1 Fault Found: 00532 - Supply Voltage B+ 53-10 - Supply Voltage Too Low - Intermittent ------------------------------------------------------------------------------- Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl Part No: 8E0 920 900 K Component: KOMBI+WEGFAHRS. RB4 D35 Coding: 01100 Shop #: WSC 00006 VCID: 2C5CB9E2DC20D078AC3 WAUZZZ8E AUZ6Z0B0245849 1 Fault Found: 00668 - Supply Voltage Terminal 30 53-10 - Supply Voltage Too Low - Intermittent ------------------------------------------------------------------------------- Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl Part No SW: 8P0 035 192 HW: 8P0 035 192 Component: RNS-E HIGH EU H44 0450 Revision: 02S Serial number: AUZBZ7D0003022 Coding: 0225413 Shop #: WSC 67032 141 14695 VCID: ECDCF9E2CCA090786C3 6 Faults Found: 00532 - Supply Voltage B+ 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 7 Fault Frequency: 1 Reset counter: 40 Freeze Frame: Voltage: 8.60 V 00446 - Function Limitation due to Under-Voltage 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 7 Fault Frequency: 1 Reset counter: 40 Freeze Frame: Voltage: 11.00 V Mileage: 655350 km Count: 1407 Clock: 12:25 00862 - Antenna for GPS Navigation (R50/R52) 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 5 Fault Frequency: 1 Reset counter: 0 Freeze Frame: Mileage: 655350 km Count: 1407 Clock: 12:24 00858 - Connection; Radio ZF Output to Antenna Amplifier 007 - Short to Ground Freeze Frame: Fault Status: 01100111 Fault Priority: 5 Fault Frequency: 1 Reset counter: 0 Freeze Frame: Mileage: 655350 km Count: 807 Clock: 21:33 00857 - CD Changer Unit (R41) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 5 Fault Frequency: 1 Reset counter: 0 02444 - Disk Drive Load / Eject Malfunction 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 5 Fault Frequency: 2 Reset counter: 40 ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl Part No: 8E0 959 433 AS Component: Komfortgerįt T01 1210 Coding: 06976 Shop #: WSC 63351 VCID: 8200B75A8E247608B6F Subsystem 1 - Part No: 8E1959801 Component: Tõrsteuer.FS BRM 0002 Subsystem 2 - Part No: 8E1959802E Component: Tõrsteuer.BF BRM 0002 Subsystem 3 - Part No: 8E0959801A Component: Tõrsteuer.HL BRM 0002 Subsystem 4 - Part No: 8E0959802A Component: Tõrsteuer.HR BRM 0002 9 Faults Found: 01330 - Central Control Module for Central Convenience (J393) 53-10 - Supply Voltage Too Low - Intermittent 01801 - Door Warning Lamp; Drivers Side (W30) 57-10 - Electric Circuit Failure - Intermittent 01705 - Selection Switch for Mirror-Adjust (E48) 27-10 - Implausible Signal - Intermittent 01331 - Door Control Module; Driver Side (J386) 53-10 - Supply Voltage Too Low - Intermittent 01332 - Door Control Module; Passenger Side (J387) 53-10 - Supply Voltage Too Low - Intermittent 01803 - Door Warning Lamp; Rear Left (W37) 57-10 - Electric Circuit Failure - Intermittent 01333 - Door Control Module; Rear Left (J388) 53-10 - Supply Voltage Too Low - Intermittent 01562 - Right Rear Door 61-00 - Won't De-Safe 01334 - Door Control Module; Rear Right (J389) 53-10 - Supply Voltage Too Low - Intermittent ------------------------------------------------------------------------------- Address 56: Radio Labels: 8E0-035-192-RNSE.lbl Part No SW: 8P0 035 192 HW: 8P0 035 192 Component: RNS-E HIGH EU H44 0450 Revision: 02S Serial number: AUZBZ7D0003022 Coding: 0225413 Shop #: WSC 67032 141 14695 VCID: ECDCF9E2CCA090786C3 6 Faults Found: 00532 - Supply Voltage B+ 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 7 Fault Frequency: 1 Reset counter: 40 Freeze Frame: Voltage: 8.60 V 00446 - Function Limitation due to Under-Voltage 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 7 Fault Frequency: 1 Reset counter: 40 Freeze Frame: Voltage: 11.00 V Mileage: 655350 km Count: 1407 Clock: 12:25 00862 - Antenna for GPS Navigation (R50/R52) 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 5 Fault Frequency: 1 Reset counter: 0 Freeze Frame: Mileage: 655350 km Count: 1407 Clock: 12:24 00858 - Connection; Radio ZF Output to Antenna Amplifier 007 - Short to Ground Freeze Frame: Fault Status: 01100111 Fault Priority: 5 Fault Frequency: 1 Reset counter: 0 Freeze Frame: Mileage: 655350 km Count: 807 Clock: 21:33 00857 - CD Changer Unit (R41) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 5 Fault Frequency: 1 Reset counter: 0 02444 - Disk Drive Load / Eject Malfunction 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 5 Fault Frequency: 2 Reset counter: 40 End --------------------------------------------------------------------- Что означает эти ошибки?
Начни с проверки аккумулятора и его контактов на клеммах, в том числе и соединения с массой. У тебя ошибка по низкому напряжение по 30 и 15 шине (клемме). Эти все ошибки надо удалить и при нормальном аккумуляторе и соединениях пробовать заводить и после этого ещё раз прочитать ошибки.
