Ответ: Кто искал на 2,2Т комплект на 500 сил? там регицца надо! Сань твои ссылки как медвежья услуга! то на не русском то еще что! заканчивай!
Ответ: Кто искал на 2,2Т комплект на 500 сил? Лови: Bolt-on turbo kit 500+ hp of my S2 I have for sale the turbo kit that has been succefully used on my S2. As most of you guys know the S2 engine is going in the Sport Quattro. It'll also get a different turbo setup. Therefore I'm selling this setup. The setup has proven results and is still in excellent shape. best 1/4 mile time is still 11.6 with this setup, and measured G-tech 530 HP and 650 NM. I ran this on the S2 with pauter rods and JE pistons. Compression was lowered with the dual headgasket mod. the Kit contains the following: -Triple-K 27#7/29 turbo with earls ano-tuff oil lines -Stainless steel #321 exhaust manifold (freshly media blasted again) without cracks -Exhaust system 3", with one rear damper, center section has seperate part for a CAT when needed to fit for MOT, ready to bolt on a coupe. Also includes seperate stainless steel wastegate downpipe. -Mapping (MRC) along with genuine RS2 ECU, MAF is used on the pressure side for this mapping. -RC injectors Price ? 3.950,00 Additionally there is also the cold side plumbing kit. This include: - Wagner intake manifold - Crossmember stainless steel - Intercooler HUGE - Tial 50 mm blow off valve, blue anodised - All SFS hoses and metal bends to use this turbo setup - Stainless hose clamps - RS2 maf Price ? 1.350,00 !One pipe is tapped for an Aquamist nozzle. The aquamist system is not included in this price. To have the setup perform optimal, one should install aquamist again. The System can be bought but I'd rather install iton the SQ again. http://www.s2forum.com/forum/attachm...d=11947246 08 I probably don't have to tell how the car performs It's insanly fast! And is still pleasant to drive. For more info about the car or setup have a look at the website www.highoctane.nl or shoot me an Email jeffer (at) highoctane (dot) nl. Please do not PM.
