вот что выдал 11.11.2 может кто знает что для начала нужно проверить. 1 Fault Found 16825 - EVAP Emission Control Sys P0441 - 002 - Incorrect Flow - MIL ON Readiness: 0010 0001
16825/P0441/001089 - EVAP Emission Control Sys: Incorrect Flow Possible Symptoms Malfunction Indicator Light (MIL) active Possible Causes Evaporative Emission (EVAP) Canister Purge Regulator Valve (N80) faulty/jammed Evaporative Emission (EVAP) Canister Purge Solenoid Valve (N115) faulty/jammed Evaporative Emission (EVAP) Canister Sealing faulty Pipes between Tank Breathing and Throttle Body leaky/blocked Possible Solutions Check Evaporative Emission (EVAP) Canister Purge Regulator Valve (N80) Perform Output Test Check Evaporative Emission (EVAP) Canister Purge Solenoid Valve (N115) Check Evaporative Emission (EVAP) Canister Perform Basic Setting Check Pipes between Tank Breathing and Throttle Body Special Notes When found in the NAR 1.8T Audi A4 1.8T check TSB 24-08-78 or 2010268/3 or Pass-Thru equivalent TSB When found in the NAR 1.8T VW Passat 1.8T check TSB 01-09-09 or 2005554 or Pass-Thru equivalent TSB Note: The Passat 26E5 or "R5" recall includes the same software update Make sure the quick release lines for the N80 valve and vacuum line to LDP are not crossed. This can also make the engine hard to start after filling up the fuel tank.
