како реле за что отвечает на А6 \45 и что за номера на них может кто от сканирует с книжки что нибуть очень надо
Ответ: како реле за что отвечает на А6 \45 Ну давай собирать... Additional relay carrier 1: 1 -Radiator fan run-on control unit (J69) 2 -Radiator fan 1nd speed relay (J26) 3 -Radiator fan 3nd speed relay (J135) 4 -Fog light relay (J5) 5 -Open 6 -Intensive Washer Pump Relay (J75) 7 -Daytime driving light switch-on relay (J90) 8 -Telephone isolation relay (J371) / Selector Lever Light Relay (J307) 9 -A/C clutch relay (J44) 10 -A/C clutch Control module (J153) 11 -Rear window wiper/washer relay (J30) 12 -Side light relay (J416) 13 -Loudspeaker current supply relay (J225) 14 -Bulb monitoring device (J123) 15 -Bulb monitoring device (J123) 16 -Servotronic control unit (J236) / Control module Alarm Horn (J31) 17 -A/C relay (J32) A1 -Front electric window thermo-fuse (S37) / Automatik window closing fuse (S99) A2 -Window lifter thermo-fuse, rear (S43) / Central locking system motor fuse (S85) A4 -Window lifter thermo-fuse (S43) A4 -Radio fuse (S92) A5 -Cigarette lighter fuse (S48) B1 -Seat adjustment thermo-fuse 1 (S44) B2 -Seat adjustment thermo-fuse 2 (S80) B4 -Terminal 30 fuse - trailer operation (S77) B3 -Door lock heating element fuse (S86) B5 -Fuse electric sliding sunroof (S83) -----Diagnostic connector: C1 - black - supply C2 - white - diag C3 - blue - transmission wiring flashing code Terminal diagnostic: K - diagnostic connector - multi-point injection L - diagnostic connector - multi-point injection) Additional relay carrier II: 1 / 2 -Starter inhibitor and reversing light relay (J226) 3 -Exterior mirror fold system control unit (J351) 4 -Exterior mirror fold system control unit (J351) 5 -Selector lever lock relay (J378) 7 -Radiator fan single fuse (S42) 8 -ABS hydraulic pump fuse (50A) (S53) / ABS valves fuse (30A) (S53) Additional relay carrier III (Taxi): 1 -Alarm system control unit (J85) 2 -Alarm system control unit (J85) 8 -Taximeter fuse and Taxi sign light bulb (blue) (S58) Central electrics - front side 1 -X contact relief relay (J59) 2 -Dual tone horn relay (J4) 3 -Headlight washer system relay (J39) 4 -Bridge connection on models with manual gearbox / Starter inhibitor relay - automatic gearbox (J207) 5 -Automatic intermittent wash/wipe relay (J31) 6 -Fuel pump relay (J17) Electronics box (в ногах пассажира): Multi-point injection control unit (J192) Lambda probe heating fuse (braun) (S73) Injector fuse (red) (S116) Ignition coil fuse (yellow) (S115) Additional relay carrier auxiliary heater (in left luggage compartment) 2 -Glow plug fuse (S66) 3 -Auxiliary heater fuse (S62) 4 -Heater fuse (S23) / 2nd battery fuse (S65) 5 -Battery cut-out relay (J7) 6 - Flame monitor control unit (J172) 8 -Fresh air blower relay (J13) Все, надоело Кто еще чего найдет - дописывайте... Перевод нужен, или и так ясно?
Ответ: како реле за что отвечает на А6 \45 А перенесите темку в FAQ плиз, чтобы не потерялась А то трудов жалко
Ответ: како реле за что отвечает на А6 \45 а можно узнать что за реле под номером 6 на 3-картинке(там где больше всего разъёмов) а то у меня место под него есть а самого реле нет!
Ответ: како реле за что отвечает на А6 \45 Пишут "Intensive Washer Pump Relay (J75)" Сразу подумал что омыватель фар, но нет - на него идет отдельное реле... Поищи в нете.
Подскажите номера реле 10 и 11 колодки пустые , толком ни чего не мог найти, а лучше сфоткайте если не лень . буду примного благодарен всем.
буква "J"и номер -это обознаение реле только на электро-схемах,на самом деле коды которые на них написаны другие!
10 - Реле включения модуля кондиционера 11 - Реле очистителя и омывателя заднего стекла У меня 10-го тоже нет, т.к. и кондиционера нет:
