Ребята подскажите на диагностике в автосервисе на улице Зорге 3 москва выявили вот такие ошибки Saturday,13,July,2013,09:17:24:32264 VCDS Version: Release 11.11.3 Data version: 20120401 -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Address 01: Engine Labels: 06F-907-115-AXX.lbl Control Module Part Number: 8E0 910 115 B HW: 8E0 907 115 C Component and/or Version: 2.0l R4/4V TFSI 0120 Software Coding: 0104010A02070120 Work Shop Code: WSC 05146 444 87954 VCID: 2045FE59F3D8C29 8 Faults Found: 004243 - Bank 1; Fuel Measuring System 2 P1093 - 008 - Malfunction - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 0 Fault Frequency: 5 Mileage: 168264 km Time Indication: 0 Freeze Frame: RPM: 2538 /min Load: 84.3 % Speed: 45.0 km/h Temperature: 75.0°C Temperature: 36.0°C Absolute Pres.: 990.0 mbar Voltage: 13.716 V 008504 - Accelerator Position Sensors (G79) / (G185) P2138 - 008 - Implausible Correlation - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 0 Fault Frequency: 3 Mileage: 168489 km Time Indication: 0 Freeze Frame: RPM: 0 /min Load: 0.0 % Speed: 0.0 km/h Temperature: 108.0°C Temperature: 78.0°C Absolute Pres.: 980.0 mbar Voltage: 12.192 V 012555 - Low Pressure Fuel regulation P310B - 004 - Fuel Pressure Outside Specification - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 0 Fault Frequency: 1 Mileage: 168731 km Time Indication: 0 Freeze Frame: RPM: 775 /min Load: 32.1 % Speed: 0.0 km/h Temperature: 97.0°C Temperature: 66.0°C Absolute Pres.: 1000.0 mbar Voltage: 12.954 V 012902 - Oxygen (Lambda) Sensor B1 S1 P3266 - 008 - Internal Resistance Implausible - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 0 Fault Frequency: 1 Mileage: 168780 km Time Indication: 0 Freeze Frame: RPM: 915 /min Load: 42.7 % Speed: 3.0 km/h Temperature: 72.0°C Temperature: 47.0°C Absolute Pres.: 1000.0 mbar Voltage: 13.208 V 000304 - Oxygen (Lambda) Sensor B1 S1 P0130 - 001 - Malfunction in Circuit - Intermittent Freeze Frame: Fault Status: 00100001 Fault Priority: 0 Fault Frequency: 1 Mileage: 168780 km Time Indication: 0 Freeze Frame: RPM: 915 /min Load: 42.7 % Speed: 3.0 km/h Temperature: 72.0°C Temperature: 47.0°C Absolute Pres.: 1000.0 mbar Voltage: 13.208 V 001287 - Idle Control System RPM P0507 - 001 - Higher than Expected. - MIL ON Freeze Frame: Fault Status: 11100001 Fault Priority: 0 Fault Frequency: 2 Mileage: 169134 km Time Indication: 0 Freeze Frame: RPM: 1050 /min Load: 13.7 % Speed: 0.0 km/h Temperature: 102.0°C Temperature: 54.0°C Absolute Pres.: 990.0 mbar Voltage: 13.462 V 008825 - Leak in Air Intake System P2279 - 002 - Freeze Frame: Fault Status: 01100010 Fault Priority: 0 Fault Frequency: 1 Mileage: 169134 km Time Indication: 0 Freeze Frame: RPM: 1082 /min Load: 13.7 % Speed: 0.0 km/h Temperature: 102.0°C Temperature: 54.0°C Absolute Pres.: 990.0 mbar Voltage: 13.335 V 008583 - Bank 1; System too Lean at Idle P2187 - 004 - Freeze Frame: Fault Status: 01100100 Fault Priority: 0 Fault Frequency: 1 Mileage: 169134 km Time Indication: 0 Freeze Frame: RPM: 1088 /min Load: 22.3 % Speed: 13.0 km/h Temperature: 104.0°C Temperature: 54.0°C Absolute Pres.: 990.0 mbar Voltage: 13.462 V Readiness: 0000 0000 и поставили диагноз снимать коллектор впускной и смотреть что с ним!!!! якобы в районе 4 цилиндра дует или сосёт!!!! и замена насоса ТНВД!!!! насчитали ремонта и запчасти со скидкой на 25000!!!! и не дали распечатку по ошибкам!!!! удалили ошибки!!! я не стал у них ни чего больше делать!!!! а сегодня сам снял ошибки и вот такие остались Sunday,14,July,2013,19:48:51:32264 VCDS Version: Release 11.11.3 Data version: 20120401 -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 8E - Audi A4 B6/B7 Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67 69 75 76 77 VIN: WAUAF68E55A436119 Mileage: 169200km/105136miles ------------------------------------------------------------------------------- Address 01: Engine Labels: 06F-907-115-AXX.lbl Part No SW: 8E0 910 115 B HW: 8E0 907 115 C Component: 2.0l R4/4V TFSI 0120 Revision: --H02--- Serial number: Coding: 0104010A02070120 Shop #: WSC 05146 444 87954 VCID: 2045FE59F3D8C29 3 Faults Found: 008825 - Leak in Air Intake System P2279 - 002 - - MIL ON Freeze Frame: Fault Status: 11100010 Fault Priority: 0 Fault Frequency: 1 Mileage: 169160 km Time Indication: 0 Freeze Frame: RPM: 808 /min Load: 14.5 % Speed: 0.0 km/h Temperature: 105.0°C Temperature: 67.0°C Absolute Pres.: 990.0 mbar Voltage: 13.208 V 001287 - Idle Control System RPM P0507 - 001 - Higher than Expected. - Intermittent Freeze Frame: Fault Status: 00100001 Fault Priority: 0 Fault Frequency: 4 Mileage: 169161 km Time Indication: 0 Freeze Frame: RPM: 1406 /min Load: 11.8 % Speed: 0.0 km/h Temperature: 107.0°C Temperature: 77.0°C Absolute Pres.: 990.0 mbar Voltage: 13.208 V 008583 - Bank 1; System too Lean at Idle P2187 - 004 - Freeze Frame: Fault Status: 01100100 Fault Priority: 0 Fault Frequency: 1 Mileage: 169171 km Time Indication: 0 Freeze Frame: RPM: 879 /min Load: 18.0 % Speed: 0.0 km/h Temperature: 72.0°C Temperature: 27.0°C Absolute Pres.: 980.0 mbar Voltage: 13.589 V Readiness: 0000 0101 и сделал опресовку из клапана ВГК из маленького отверстия дует!!!!! на холостых обороты плавают машину потряхивает!!!! на ходу вроде бы нормально!!!! подскажите что делать !!!! понятно что клапан менять!!! завтра сделаю!!!!
вот свежак!!!! а как её сделать чтобы меня не нае,,,,,ли!!!! я уже сделал раз и что???????? Monday,15,July,2013,21:26:06:32264 VCDS Version: Release 11.11.3 Data version: 20120401 -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Address 01: Engine Labels: 06F-907-115-AXX.LBL Control Module Part Number: 8E0 910 115 B HW: 8E0 907 115 C Component and/or Version: 2.0l R4/4V TFSI 0120 Software Coding: 0104010A02070120 Work Shop Code: WSC 05146 444 87954 VCID: 2045FE59F3D8C29 7 Faults Found: 008825 - Leak in Air Intake System P2279 - 002 - - MIL ON Freeze Frame: Fault Status: 11100010 Fault Priority: 0 Fault Frequency: 1 Mileage: 169160 km Time Indication: 0 Freeze Frame: RPM: 808 /min Load: 14.5 % Speed: 0.0 km/h Temperature: 105.0°C Temperature: 67.0°C Absolute Pres.: 990.0 mbar Voltage: 13.208 V 001287 - Idle Control System RPM P0507 - 001 - Higher than Expected. - Intermittent - MIL ON Freeze Frame: Fault Status: 10100001 Fault Priority: 0 Fault Frequency: 7 Mileage: 169161 km Time Indication: 0 Freeze Frame: RPM: 1406 /min Load: 11.8 % Speed: 0.0 km/h Temperature: 107.0°C Temperature: 77.0°C Absolute Pres.: 990.0 mbar Voltage: 13.208 V 008583 - Bank 1; System too Lean at Idle P2187 - 004 - - MIL ON Freeze Frame: Fault Status: 11100100 Fault Priority: 0 Fault Frequency: 1 Mileage: 169171 km Time Indication: 0 Freeze Frame: RPM: 879 /min Load: 18.0 % Speed: 0.0 km/h Temperature: 72.0°C Temperature: 27.0°C Absolute Pres.: 980.0 mbar Voltage: 13.589 V 000768 - Random/Multiple Cylinder Misfire Detected P0300 - 008 - - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 0 Fault Frequency: 1 Mileage: 169206 km Time Indication: 0 Freeze Frame: RPM: 1239 /min Load: 20.0 % Speed: 0.0 km/h Temperature: 39.0°C Temperature: 36.0°C Absolute Pres.: 980.0 mbar Voltage: 12.954 V 000771 - Cylinder 3 P0303 - 008 - Misfire Detected - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 0 Fault Frequency: 1 Mileage: 169206 km Time Indication: 0 Freeze Frame: RPM: 803 /min Load: 20.8 % Speed: 0.0 km/h Temperature: 46.0°C Temperature: 34.0°C Absolute Pres.: 980.0 mbar Voltage: 13.970 V 000772 - Cylinder 4 P0304 - 008 - Misfire Detected - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 0 Fault Frequency: 1 Mileage: 169206 km Time Indication: 0 Freeze Frame: RPM: 803 /min Load: 20.8 % Speed: 0.0 km/h Temperature: 46.0°C Temperature: 34.0°C Absolute Pres.: 980.0 mbar Voltage: 13.970 V 000770 - Cylinder 2 P0302 - 008 - Misfire Detected - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 0 Fault Frequency: 1 Mileage: 169206 km Time Indication: 0 Freeze Frame: RPM: 803 /min Load: 20.8 % Speed: 0.0 km/h Temperature: 46.0°C Temperature: 34.0°C Absolute Pres.: 980.0 mbar Voltage: 13.970 V Readiness: 0000 0101 я и спрашивал как и что сделать если знаете подскажите??!!!!
Так ты иди в сервис. Скажи так и так, такие траблы. Не нравится мне моя машина. Напиши все в заказ-наряде. Спроси сколько исправить. Если цена устраивает пусть делают за результат.
