1. Дорогие одноклубники!
Audi A1 quattro Limited-production Official Photo + Press Release
Тема в разделе "A1", создана пользователем Lost, 21 дек 2011.
  1. Lost
    Lost Старожил
    1 янв 2003
    8.606
    Эска - с*ка зло
    The new head of the compact class: The Audi A1 quattro
    Limited-production (333 units) A1 quattro beginning 2012
    188 kW (256 hp), quattro drive, 0 – 100 km/h in 5.7 seconds
    Dynamic look inside and out, thoroughly equipped
    Audi is crowning its successful A1 model series with an exclusive top-of-the-line model. The dynamic A1 quattro, limited to just 333 units, moves to the head of the compact class. Its two-liter, turbocharged engine produces 188 kW (256 hp) and 350 Nm (258.15 lb-ft) of torque, which is delivered to all four wheels. The Audi A1 quattro sprints from zero to 100 km/h (62.14 mph) in 5.7 seconds and has a top speed of 245 km/h (152.24 mph).
    The A1 quattro is powered by the 2.0 TFSI engine. The 1,984 cc, four-cylinder engine combines gasoline direct injection with turbocharging in the classic Audi manner. Among its highlights are the adjustable intake cam shaft and the two balance shafts, which ensure smooth operation. Maximum torque of 350 Nm (258.15 lb-ft) is continuously available between 2,500 and 4,500 rpm, and peak power (188 kW/256 hp) is developed at 6,000 rpm.
    Every detail of the sporty, sonorous four-cylinder engine has been optimized for high performance and low fuel consumption. Common rail injection, a turbocharger with intercooler and a regulated oil pump are just a few examples. The Audi A1 quattro is expected to consume on average less than 8.5 liters of fuel per 100 km (27.67 US mpg). Yet it performs like a top-notch sports car: The standard sprint takes just 5.7 seconds, and top speed is 245 km/h (152.24 mph).
    The 2.0 TFSI delivers its power to the quattro permanent all-wheel drive system via a precisely shifting six-speed transmission, bringing Vorsprung durch Technik to the small-car class. The heart of this system is an electronically controlled, hydraulically actuated multi-plate clutch whose package of plates rotates in an oil bath.
    During normal driving, the clutch sends most of the engine’s power to the front wheels. If traction decreases there, the clutch can transfer torque steplessly to the rear axle in just a few milliseconds by forcing the packages of plates together by a defined amount. A pressure reservoir helps the electric pump to develop the oil pressure. If a wheel on one of the axles should slip, it is braked by the electronic differential lock (EDL).
    The placement of the multi-plate clutch at the rear axle provides for a harmonious distribution of the axle loads, and the chassis of the Audi A1 quattro has been adapted to the dynamics of the drivetrain. It is much more tautly tuned than that of the production model. The front suspension is a McPherson construction; a four-link axle is used at the rear. The sensitive and efficient electrohydraulic power steering has a sporty, direct 14.8:1 steering ratio.
    The Audi A1 quattro rolls on 8.0 J x 18 cast alloy wheels. They are Glacier White, feature an exclusive turbine design and are fitted with 225/35-series tires. The internally vented front brake discs measure 312 millimeters (12.28 in) in diameter and are gripped by black calipers. The ESP stabilization program includes a sport mode and can be switched off entirely for a trip to the race track, for example.
    One look is all it takes to see that the Audi A1 quattro is a very special vehicle. It is available only in Glacier White metallic, and its roof is painted high-gloss black. The front bumper is muscular, the frame and grate of the single-frame grille are high-gloss black. The curved bars in the headlights – the wings – are red. The grille, the roof arch and the rear hatch sport quattro badges.
    The rear windows are tinted; the roof flows into a large, two-color wing. The color black accentuates the rear hatch and the diffuser. The LED rear lights are tinted; the rear bumper sports a distinctive look. The exhaust system terminates in two polished dual tailpipes on the left and the right, each measuring 100 millimeters (3.94 in) in diameter. The A1 quattro is 3,987 millimeters (13.08 ft) long, 1,740 millimeters (5.71 ft) wide and 1,416 millimeters (4.65 ft) tall, making it somewhat longer than the model on which it is based. Luggage capacity is 210 liters (7.42 cu ft); folding down the rear seats increases this to 860 liters (30.37 cu ft).
    Cool, sporty black dominates the interior of the Audi A1 quattro. The seats and the armrests on the doors are covered in Silk Nappa leather with contrasting red seams. The S sport seats up front have pronounced bolsters, integrated head restraints and a quattro badge on the backrest covers. The seats feature multi-way adjustment. The lower section of the center console shines in high-gloss black; the footrest and the pedal caps are made of brushed stainless steel. Red seams frame the floor mats, and the door sill trims bear A1 quattro badges.
    The instrument cluster has a number of eye-catching features, including white needles, a red tachometer, the quattro logo and the color display for the driver information system. The multifunction sport steering wheel is flattened at the bottom, wrapped in leather with contrasting red stitching and sports the car’s serial number. The shift lever knob is made of aluminum. Many control elements have an aluminum-look finish.
    The Audi A1 quattro will be available from the second half of 2012 and will be supplied to customers with a full range of equipment. It includes many features taken directly from the luxury class, including xenon plus headlights, high-beam assistant, adaptive brake lights, LED interior lighting package, light and rain sensor, automatically dimming interior mirror, rear parking system, automatic air conditioning, alarm system, storage package, convenience key and cruise control.
    The infotainment equipment likewise leaves nothing to be desired. It includes a CD changer, a digital radio tuner, the Audi music interface and MMI navigation plus. The Bose sound system drives 14 speakers with 465 watts of power; the woofers in the doors are indirectly lit with light guide LEDs. Audi connect uses the Bluetooth online car phone to connect to the Internet and deliver special web services, including Google Earth, to the car. Passengers can also connect their mobile devices to the integrated WLAN hotspot.
  2. Lost
    Lost Старожил
    1 янв 2003
    8.606
    Эска - с*ка зло
  3. Lost
    Lost Старожил
    1 янв 2003
    8.606
    Эска - с*ка зло
  4. al mazud
    al mazud Живу я здесь
    20 июн 2007
    3.285
    q3 2.0tq '14
    никак ауди в ралли собралась ? =) уж очень похоже на на шкоду s2000
  5. kjes
    kjes Ауди Центр Север
    18 июн 2009
    683
    Audi A6, Mazda6
    и конечно на ручке))
  6. Mikseer
    Mikseer Участник форума
    13 мар 2010
    401
    А3 2.0TQ, 09 м.г.
    Дорого и беспощадно! :)
  7. Ubber
    Ubber Новичок
    12 дек 2011
    4
    А1
  8. Mikseer
    13 мар 2010
    401
    А3 2.0TQ, 09 м.г.
    Ценник будет между S3 и RS3, скорее ближе к RS3 :)
  9. Matteo
    Matteo Участник форума
    29 ноя 2011
    276
    A2/8Z 1.4 TDI 2003
    забавно... неужели именно ЭТОГО не хватало в линейке ;)
    или это просто статусная отметка, чтобы соответствовать заряженным модификациям мини?
  10. lassa
    lassa Участник форума
    6 окт 2006
    109
    Audi A4 TFSI
    красота. толковая тачка вроде.
  11. happyhar
    happyhar Живу я здесь
    8 мар 2008
    2.978
    Audi 90 2.3 SE'91.АКПП.
    красивый, и очень грозный вид у этого малыша. очень похоже на раллийный авто..
  12. Titofff
    Titofff Живу я здесь
    5 ноя 2006
    1.924
    А3 2.0T Q MT6
    Видятся некоторые мотивы под Лянчу Интеграле...
  13. konretiff
    konretiff Новичок
    13 июл 2012
    2
    A6 allroad 3.0 TDI
    Копейка не заряженная прекрасно едет, а эта наверняка зажигалка.
  14. TTRSTTRS
    TTRSTTRS Новичок
    23 июл 2012
    3
    TTRS
    красивая
  15. LemmingSPB
    LemmingSPB Новичок
    16 июн 2012
    24
    А4 2.0T
    #15 LemmingSPB, 22 окт 2012
  16. Вoвчик
    Вoвчик Участник форума
    21 май 2009
    421
    A3 Sportback
    Стоить будет наверно как чугунный мост. Если цена как S3 то нафиг эту заряженную оку ))
  17. Chek1st
    Chek1st ai
    18 фев 2009
    16.106
    TLC TDi bigbibik
    в польше видел :) чума тачка всего 333 будет.... 2л турбо...
    по комплектации все с класса люкс + полный привод с ручкой
    60т евриков не бюджет, бонусом короткая база - не хватает только каркаса)))
