шайтан программа
Тема в разделе "Тюнинг", создана пользователем Igors, 19 май 2008.
  1. Igors
    Igors Заблокирован
    23 июл 2004
    11.265
    Венесуэла
    Q5 3.0D и Q7 ( 7 мест ) 3.0D
    Сея программа была взята с иносранного форума мегатюнеров Ауди.:eek:
    Судя по пунктам, можно изменять обогощение топлива.:rolleyes:
    Никто не хочет попробовать?:dead:
    http://www.ecodetuning.com/revo/Lemmiwinks.exe
  2. Igors
    Igors Заблокирован
    23 июл 2004
    11.265
    Венесуэла
    Ответ: шайтан программа
    for all those interested this is ripped off from vw vortex:
    you can download lemmiwinks at:
    Ch01 : Idle Speed Offset
    Adjust idle RPM level
    - Higher number: increase idle rpm
    - Lower number: decrease idle rpm
    Ch02 : Fuel Tweak (Accel Pump); Increasing Loads
    -This channel adjusts a fuel enrichment under load
    -Modulates Throttle Response
    Ch03 : Fuel Tweak (Accel Pump); Decreasing Loads
    -This channel adjusts a fuel enrichment term coming off the gas or decelerating.
    Ch04 : Start Up Fuel Enrich
    Amount of fuel on any start ups?
    - Higher number: enrich the mix
    - Lower number: lean out the mix
    Ch05 : Warm Up fuel Enrich
    Amount of fuel on start ups E.G. on the first start in the morning?
    Ch06 : Lambda Regulation
    Controls how fast ECU adapts:
    - Higher number: faster adaptation
    - Lower number: slower adaptation
    Ch07 : Additive Offset To Speed Limiter
    Controls speed limiter in increments ok 1km/hr
    Ch08 : Secondary Fuel Tweak
    Controls fueling at idle, ussually alters additive fuel trims
    - Higher number enrich the mix
    - Lower number lean out the mix
    Ch09 : Ignition Timing Offset
    Controls timing in steps of 0.75 degrees, all RPM range is altered
    - Higher number advances timing
    - Lower number retards timing
    Ch10 : Primary Fuel Tweak
    Controls fueling on run, ussually change multiplicative fuel trims
    Ch11 : Unused
    Unused
    Ch12 : SEL Scaling (Turbo Cars Only)
    Adjust boost
    - Higher numbers increase boost pressure
    - Lower numbers decrease boost pressure
    Ch13 : OFF OFF
    Unused
    Ch14 : Idle Torque Additive Offset
    Controls engine load at idle
    - Higher numbers: spec load at idle is increased
    - Lower numbers: spec load at idle is decreased
    Aditional Information from Revotechnik:
    Adaptation Channer Explanation
    http://forums.vwvortex.com/zerothread?id=1191064
    Revo Comparison of Adaptation Channels and Tuning
    http://forums.vwvortex.com/zerothread?id=1191128
    How to:
    1. Place key in ignition, turn to on position.
    2. Attach VagCom 'dongle'.
    3. Bring up Lemmiwinks software
    4. To store original ECU settings Click ON "Read". This reads your current settings.
    5.Adjust settings at will.
    6.Click on 'SET' to connect to the ECU and adapt settings.
    7. When asked to cycle ECU, simply turn it off, then turn the ECU back on.
    8. Enjoy (hopefully) new settings.
    Hints
    1. Take off your Instrument Cluster Fuse if you can't establish communication with the ECU. clear airbag DTCs.
    Special thanks to Don R, MRP2001GTi and BMFJETTA for great information.
    Present:
    2001 TT 225hp TQM, Valentine One, K40 laser diffuser, and an L7 in the trunk
    Past:
    2001 ming 2.8
  3. Thomas
    Thomas Новичок
    24 окт 2006
    22
    Audi S4/C4 AAN
    Так и чво, пробовал кто? :)
  4. AVANTgardist
    AVANTgardist Новичок
    5 окт 2008
    86
    Audi A4/B5 1.8Tq A
    #4 AVANTgardist, 24 фев 2009
    с первого взгляда просто безделушка по моему, меняет те же каналы адаптации что и доступны через вагком, разница лишь в том что не нужно вводить логин :)
  5. Tolik-Msk
    Tolik-Msk Завсегдатай
    1 июн 2007
    852
    WK2 3.0
    все верно ... ели есть логин она не к чему, у меня его нет на выхах хочу попробовать изменить кол-во впрыска, спасибо malkon -у :rock:
  6. sergeynik S6
    sergeynik S6 Живу я здесь
    27 янв 2005
    3.415
    Tesla model X 2020
    если только на стадии запуск и прогрев остальное безсмысленно
    1 человеку нравится это.
  7. Igors
    Igors Заблокирован
    23 июл 2004
    11.265
    Венесуэла
    Я пробовал . У меня не пошла программа. Не приконектилась почемуто.:shock:
  8. Igors
    Igors Заблокирован
    23 июл 2004
    11.265
    Венесуэла
    Это какие каналы есть смысл трогать и что из этого может получится?
  9. melkon
    melkon Суровый диагност
    21 сен 2005
    27.088
    Tuareg NF 3.0TDI на пневме.
    #9 melkon, 27 фев 2009
    Ну ведь ей же и УОЗ крутить можно (некоторым необходимо его подрезать чуток) И обороты ХХ. И еще ее главная фича - как заявлено производителями может приподнимать ограничитель скорости . Но в принципе так подстройщик .
  10. Igors
    Igors Заблокирован
    23 июл 2004
    11.265
    Венесуэла
    #10 Igors, 28 фев 2009
    Channel 01 - настройка оборотов холостого хода.
    Channel 02 - подстройка состава смеси, при увеличении нагрузки. обогащение смеси под нагрузкой, когда тапка нажимается резко.
    Channel 03 - подстройка состава смеси, при уменьшении нагрузки. обогащение смеси при плавном нажатии на тапку или при замедлении.
    Channel 04 - обогащение в фазе *после старт*
    Channel 05 - обогащение в фазе *прогрев*
    Channel 06 - лямбда-регулирование. Задает скорость реакции контроллера на изменение сигнала с лямбды, большие значения - реакция быстрее,
    меньшие значения - реакция медленнее.
    Channel 07 - дополнительная компенсация ограничителя скорости. Задает ограничение, добавляя по 1км/час
    Channel 08 - отвечает за обогащение в фазе "старт".
    Channel 09 - компенсация угла опережения зажигания. Регулирует угол с шагом 0.75 градуса во всем диапазоне оборотов
    Channel 10 - базовый коэффициент подстройка по топливу (работает во всех режимах)
    Channel 11 - рециркуляции выхлопных газов (EGR/AGR)
    Channel 12 - настройка давления наддува, только для турбо машин, меньшие значения - уменьшают давление наддува.
    Channel 13 - не используется
    Channel 14 - дополнительная компенсация момента на х.х. Регулирует нагрузку двигателя на холостом ходу большие значения - увеличивают спецификацию по нагрузке на холостом, меньшие значения – уменьшают.
  11. melkon
    21 сен 2005
    27.088
    Хрена лысого . Давление можно крутить только в сторону понижения .
  12. michфуд
    michфуд Старожил
    12 окт 2005
    15.243
    A4 8E 2,0 01
    на 2 литра скока даст прибавку в лысых?
  13. GrayCep
    GrayCep Старожил
    3 окт 2005
    5.061
    A4 1.8TQM 8EC
    Открутить можно только общим смещением, это не есть хорошо.
    В основном вверху и в середине надо убавить, причем по разному в каждом случае.
    Если предел регулировки оборотов на хх прописаны константами, как на bfb, то тоже болт.
    Но прога безусловно интересная, поиграться можно.:thumbup:
  14. circoloco
    circoloco Участник форума
    5 фев 2009
    192
    Audi А4/B6 1.8T AMB 03г
    я было уже обрадовался:bt:
  15. awarec
    awarec Новичок
    21 сен 2014
    65
    А4/B6 1.8TQ 02 amb USA
    хочу выставить этой программой угол зажигания - 7.5 градусов , также и выставлять - 7.5 или она считает на оборот .Или выставить 7.5 короче запутался
