В Эльдорадо ХАЛЯВНЫЕ ноутбуки Асус Ноутбук ASUS Ноутбук ASUS X55S X55Sv Series Notebook PC www.asus.com Specifications BIOS AMI BIOS code 8MB Flash EPROM PMU, Plug & Play Boot from USB, LAN,Ai-Flash 3,Ai-Flash 4, Ai-Flash 5 Chipset Intel PM965 Series (Crestline PM) 667/800MHz FSB ICH8M Main Memory 2048Mb 2 x SODIMM Sockets for Expansion Up to 4 GB (BTO Option) Dual Channel DDR2 667 DRAM support Display 15.4” WXGA+ Dual Channel LVDS I/F Graphics & Video Module Nvidia GeForce9500M GS 512MB(8pcs) MXM Connector DX10 Support H.264/VC-1 Hardware decoding HDCP support PC Cards Slot One built-in Eight in one card reader support MMC/ SD/ Mini-SD/ XD/ Memory Stick/ MS Pro/ MS-Duo/ MS-Pro-Duo ,support push/push Hard Disk Drive 12.5mm SATA HDD SATA 160G Reserve 9.5mm SATA HDD Optical Storage Device Fixed Type Connectivity Intel Kedron 802.11a/b/g/n supported ( Mini Card) (Support Antenna 2x3 and 2x2) 802.11a/b/g (BTO option) (a/b/g EU/RW/JP/NA, b/g CH1~11/CH1~14), Antenna supports 802.11a/b/g, Intel 3945ABG supported Integrated MDC Fax/ Modem Azalia Compliant and V.92 / K56flex support On board 10/100/1000 Mbps Fast Ethernet Controller Full and Half duplex mode support for 10/100/1000 Mbps MODEM supported V.90 and universal PPT ( CTR 21, JATE, FCC, A-tick, DGT, Built in Mini-Card Interface WWAN module 3G/3.5G Antenna support USB Interface Keyboard 340mm keyboard with Ten-keys and MS Windows 19 mm full size, with MS-Windows Vista function keys Interface 1x VGA port/Mini D-sub 15-pin for external monitor 4x USB 2.0 ports (One External SATA & USB 2 in 1, one with USB Charger function under S5 AC mode) 3 Audio jack: Audio out/SPDIF/Mic-in (Ready for WWAN) One LAN RJ-45 and One Phone RJ-11 Jack 1x 1394 B Type jack 1 x CIR for remote control 1x SIM card slot reserve Wireless/BT/3G Switch One Kensington Lock Video Camera Fixed1.3M Pixels Video Camera with LED (option) LED Lighting TouchPad Touchpad Audio Built-in Azalia compliant audio chip, with 3D effect & full duplex Built-in Stereo Speakers(1.5W/2W, TBD) and microphone S/W Volume up/down Support Audio Jack Detector for Vista Basic Logo Support Audio CODEC criteria for Vista Premium Logo Build-in speakers microphone AC adapter Output : 19V DC, 4.74A, 90W Input : 100~240V AC, 50/60Hz universal 3/ 2 pin compact power supply system Pointing Device Built-in Touchpad Two click buttons with scroll area Dimensions/Weight 375x 265 x 34.3~40.6 mm 2.8kg with 6 cell battery цена 29900 руб помоему не плохо, хотя может уже боян в тему http://forum.ixbt.com/topic.cgi?id=17:30010 http://www.eldorado.ru/cat/detail/71019183/ http://www.bmwclub.ru/vb/showthread.php?t=170797
Ответ: В Эльдорадо почти халявные ноутбуки Асус почитай ссылки в первом сообщении.........я ломанулся в эльдорадо, там поржали .......сказали как только их привозят (не больше 4) они улетают как пирожки.......сказали только через инет.......БМВешники давно уже таряться
Ответ: В Эльдорадо почти халявные ноутбуки Асус Баян это - купил я его позавчера. Есть и плюсы, есть и минусы... Пластик например не очень, зато мощща! И сумка в комплекте с мышкой (если не дают, вызывайте менеджера, судя по форуму на ixbt несколько не чистых на руку продавцов потеряли через эту сумку работу) Все игры что у меня были, шли на макс. настройках с разрешением 1440 х 900 Тихий, клава с цифровой клавиатурой, пишут про плохие углы обзора - ну не сони, но лучше чем мой sams r50. Жалуются на громкий привод - вроде сильно не шумел, поставил замедлялку на него программную. Виста - это, да, гадость. Если бы я себе брал, поставил бы хр, но я брату брал, его и виста устраивает. Батарейка слабая, примерно на полтора часа. Если есть вопросы - спрашивайте.
Ответ: В Эльдорадо почти халявные ноутбуки Асус Видео - аналог полный почти 8600 gt - не самая плохая на сегодня карточка.
Ответ: В Эльдорадо почти халявные ноутбуки Асус Меня как и 98% покупателей этого ноута пытались кинуть на сумку!!! Кто будет брать, запомните ноут (в белой коробке) и сумка находятся в серой коробке запечатанной на заводе асус (есть на фото)!!! Эсли дают только белую коробку то значит сперли сумку, а сумка класcная . Первая фраза менеджера при покупке: "какую сумку будете брать к ноуту".........Еще они разводят на дополнителную гарантию
Ответ: В Эльдорадо почти халявные ноутбуки Асус пасибо за фото...насчет сумки да... недавно покупали асус (не такой) там было 2 каробки, 1 где сам комп и 2 где комп и сумка.
Ответ: В Эльдорадо почти халявные ноутбуки Асус Темы про этот ноут, здесь и на БМВклабе, сделали неплохие продажи Эльдорадо
