Ответ: пробейти срочно VIN плиз A00 A8S B0A B37 C00 CD4 E0A F0A FA0 FC0 FQ0 G0Q H4Z J1R K8X L0L MK5 N5A NT1 P24 PAP PLL PND PPB PSH Q1N QA0 QH0 QV1 SA7 T7Z U1C V0A VC0 VX0 VY0 X4M 0DS 0F2 0G7 0GV 0JZ 0N6 0SN 0VU 0W2 0YZ 1BY 1C2 1D0 1E1 1EY 1KD 1LA 1N1 1PC 1QD 1SE 1T3 1VH 1WG 1X1 1YD 1Z2 2A4 2B5 2C5 2G1 2K0 2T1 2WA 2Z1 2ZS 3B0 3C7 3CB 3F1 3FE 3GD 3HA 3L5 3NZ 3Q6 3S1 3V0 3X0 3Y0 4A4 4E0 4GH 4K4 4KC 4L6 4N0 4UE 4W0 4X1 4ZB 5A5 5C8 5D1 5E4 5J0 5K5 5RU 5SL 5TS 6E3 6FB 6M1 6PC 6Q2 6R0 6SS 6U0 6V1 6W5 6XK 7A0 7AH 7E0 7K0 7M3 7P1 7Q2 7QA 7X2 8AY 8GU 8JG 8K0 8N4 8Q3 8T1 8TC 8X1 8Z6 9AK 9B0 9M0 9NX 9P0 9Q2 9VD 9W0
Ответ: пробейти срочно VIN плиз Расшифровка кодов комплектации Код Опция 5TS decorative burr walnut inserts, natural, high-gloss 4X1 side airbag front 9Q2 multi-function indicator/on-board computer with check control 9B0 without telepay device 8T1 cruise control system (CCS) FQ0 standard production wheels 3L5 electric seat adjustment for both front seats 1YD transmission shafts for rear axle diameter 108 1C2 antifreeze up to -35 degree celsius tolerance up to -40 degree C 0F2 fuel system for carburetor gasoline engine 1BY 4-corner air suspension for rough-road design L0L left-hand drive vehicle 8TC rear fog light for driving on the right QH0 without voice control 7P1 power adjustable lumbar support in frontseats 7A0 without CD changer/CD player 1Z2 increase in initial standard fuel filling H4Z all-terrain tires 225/55 R 17 W 0N6 rear axle with reduced tread VX0 without hands-free system Q1N reinforced standard seat, front CD4 cast alloy wheels 7 1/2J x 17 5-arm style, offset 25 2WA without additional tires QA0 without child seat T7Z components for base engine, unit 078.8 B0A component parts set without country-specific design requirement G0Q five-speed automatic transmission for four-wheel drive vehicle 7X2 ultrasonic park distance control front and rear FC0 without customized installation 1D0 without towing attachment 2A4 delivery equipment for shipment (transitcoating) with thick seat cover 1KD disc brakes, rear 7AH electronic vehicle immobilization devicewith alarm system, passenger compartmentcontrol and backup horn 0G7 Tiptronic 3F1 collapsible spare wheel 8N4 windshield wiper intermittent control with potentiometer (four speeds) 7Q2 navigation system with color screen 6SS luggage compartment floor covering X4M national sales program CIS 6E3 center armrest front 1SE additional engine guard (body-dependent) VY0 without danger alarm system 4K4 radio remote controlled central locking operated from inside and separate trunk release 7QA without CD ROM 3FE electric slide/tilt sunroof with sun screen/sunblind 1LA disc brakes, front 6M1 tie down straps 1E1 activated carbon canister 1T3 first aid kit and warning triangle 2B5 additional exterior noise suppression E0A no special edition 0W2 label for central electric English-speaking countries 0VU information kit in Russian 4ZB bright moldings 3V0 without child bench seat 0GV emissions concept EU 2 (critical vapor pressure) 5A5 trunk lining, with stowage trays 4KC side and rear windows tinted VC0 w/o remote-controlled garage door opener 6U0 without additional seals outside 4L6 breakaway inside rear view mirror automatically dimming 7K0 without tire pressure warning light 3GD plane rear cargo area 8GU alternator 140A 6FB body-colored outer rear view mirror housings 3NZ rear seat bench unsplit, backrest split folding 2C5 axial and vertical adjustable steering column J1R battery 420 A (82 Ah) 9M0 without auxiliary/parking heater 4E0 tailgate/trunk lid unlocking from outside N5A leather seat covering "Cricket" 1EY special identification plate with weight data, but without general operating permit (ROW) C00 operating permit, initial registration 2Z1 type sign at rear and "Quattro" nameplates respectively 2K0 standard bumpers 6V1 rear trim panel (ECE) 1N1 power steering B37 type approval CIS (without the Baltic States, Ukraine and White Russia) 5J0 without rear spoiler NT1 transit coating (type 2) 8X1 headlight washer system 3HA without leather parts scope 3X0 without load-through provision 8Q3 automatic headlight-range adjustment dynamic (self-adjusting while driving) 5C8 additional body measures 2ZS leather trimmed multi-function steering wheel with Tiptronic 7E0 w/o heat accumulator/auxiliary heating 8AY radio/navigation system U1C instrument insert with km/h speedometer,clock, tachometer, trip odometer and add. instruments (volt., oil temperat.) 6W5 front license plate bracket 1VH installation parts for six-cylinder engine 4N0 standard dashboard 5K5 transit protective film (instead of paint preservative) 4UE airbag f. driver a. front seat passenger 3B0 without additional child seat anchor 2T1 double-sized standard (DIN) 3Q6 three rear headrests 7M3 scuff plates in door apertures F0A no special purpose vehicle, standard equipment A00 no self-collection 5D1 carrier frequency 433.92 MHz 5RU outer right rear view mirror: convex (large viewing field) 3Y0 without roll-up sun screen 9VD speaker (active) 0YZ without determination of weight categoryfor rear axle 0JZ without determination of weight categoryfor front axle 9NX without electronic logbook 8JG headlight with gas discharge lamp for driving on the right 6PC leatherette hand brake lever handle 1WG transmission shaft w/ 88mm in diameter 9W0 w/o car phone preparation/installation K8X Station Wagon "allroad" 8K0 without special low beam mode 5SL outer left rear view mirror: non-spherical 8Z6 engine cooling system, type 2 4GH windshield tinted with windshield sunshield 1X1 four wheel drive 3C7 3-point seat belt for center rear seat 6Q2 leather gearshift knob/handle 1PC wheel bolts with anti-theft protection (unlockable) 4W0 without cassette and CD storage unit 9P0 without seat belt warning light 5E4 sill top with door cover 6XK outer rear view mirrors: powered, heatedelectrically foldable, automatically dimming 3CB removable net partition FA0 control of standard production V0A tires w/o specification of tire brand 0SN labels/plates in Russian A8S standard equipment 0DS installation differentiation for build status of vehicle class 4B0 (AUDI) 3S1 bright roof rails QV1 TV reception 4A4 seat heater for front and rear seats separately controlled MK5 6-cyl. gasoline engine 2.7 L/184 kW 30V base engine is T7Z SA7 inventory control model 2 2G1 insert for the filling up of unleaded fuel 6R0 selector lever cover 9AK Climatronic with impact pressure control free of cfc 1QD special plates/stickers/ safety certificates for CIS Нераспознанные коды PSH PLL PND P24 PPB PAP Введите коды комплектации
Ответ: пробейти срочно VIN плиз спасибо инфу, еще вопрос можно ли пробить по вину кем продана и где обслуживалось?
Ответ: пробейти срочно VIN плиз недают инфи т.к. я еще не владелец, только собираюськупить, причем недоют негде ни в салоне где была продана, на в представительстве AUDI В салоне только потвердили факт продажи и всё
Ответ: пробейти срочно VIN плиз Я во вторник (22.08.06) гонял это авто на диагностику в Ауди-Центр Москва. Приговорили к замене левую турбину.
Ответ: пробейти срочно VIN плиз WAUZZZ4BZWN153657 Регион: Германия Производитель: Audi Город: Neckarsulm (Германия) Модельный год: 1998 (Внимание! Модельный год начинается на 4-5 месяцев раньше календарного. Например, автомобиль выпущеный в ноябре 1983 года будет промаркирован 1984-ым модельным годом.) Больше чёт ничё не выдаёт =)))....
Ответ: пробейти срочно VIN плиз WAUZZZ8DZWA167881; 8D50C4; E7E7BR; ADR; 404500; DDU; 21 ; 23/03/1998; A8S/G0C/K8D/M51/T5Z/0DY/0K0/1VG/1X0/C09/S5U/0TD/2Z0/3CB/5MG/6E3/6RA/PH5/PSV/PW1/P15/RCL/WM1/N4G/1MR/4A3/6Q2/6R2/6XD/8GD/8RN/8UD/9AK/9T1/9X6/B0A/B99/C8N/E0A/FA0/F0Y/H6S/J1P/L0L/Q1A/U1A/0G1/0JE/0LW/0ST/0VC/0YD/1AC/1BA/1C1/1D0/1EX/1E1/1G3/1LZ/1PA/1SA/1S7/1T3/1WC/1YA/1Z0/2A5/2B0/2G1/2K1/2WA/3B0/3C7/3FA/3L1/3NZ/3Q6/3S0/3X0/3Y0/4F1/4GH/4L2/4M6/4R2/4SB/4TB/4UE/4W0/4X1/4ZE/5C0/5D0/5E1/5K1/5RQ/5SL/6M0/6N0/6U0/6V1/6W5/7AA/7A0/7CA/7M0/7P0/7QA/7Q0/7X0/8BG/8CC/8KA/8K0/8N4/8Q1/8R1/8S4/8TC/8T0/8X0/8Z5/9P0/9Q0/9W0/9Y0
