Скоро будет в Москве америкос, история неизвестна. Говорят, что отчуждение страховой, хотя хз. Буду очень признателен если поможите вин: WAULC68E92A193248
Ответ: пожалуйста помогите пробить машину... VIN: WAULC68E92A193248 Код модели: 8E252Z () Дата выпуска: 21.12.2001 Модельный год: 2002 Код и номер двигателя: AMB 013321 Код КПП: FEP Комбинация цветов интерьера: LF Комбинация цветов кузова: A2 Цвет крыши: A2 Комплектация автомобиля (код и наименование): 0CS vehicle class differentiation 8E0 0F2 fuel system for carburetor gasoline engine 0G7 Tiptronic 0GN emissions concept ULEV 1 0JJ weight category front axle weight range 9 0LB special plates/stickers/safety certificates for USA 0SS labels/plates in English and French 0TD front and rear floor mats 0VM information kit in American English 0W2 label for central electric English-speaking countries 0YK weight category rear axle weight range 10 1BE sports suspension/shock absorption 1C2 antifreeze up to -35 degree celsius tolerance up to -40 degree C 1D0 without towing attachment 1EP special identification plate (USA) 1G3 alloy spare wheel with original equipment tires 1KD disc brakes, rear 1LE disc brakes, front 1MU leather trimmed sports steering wheel for airbag system with Tiptronic 1N1 power steering 1PA standard wheel bolts 1SA without additional engine guard 1T3 first aid kit and warning triangle 1VG installation parts for four-cylinder engine 1W0 without refrigerator/glove compartment cooling system 1WG transmission shaft w/88mm in diameter 1X1 four wheel drive 1YF transmission shafts for rear axle diameter 75.5 1Z6 increase in initial standard fuel filling 2G1 insert for the filling up of unleaded fuel 2K2 reinforced bumpers 2T1 double-sized standard (DIN) 2V5 fresh air intake system with activated charcoal canister 2WA without additional tires 2Z1 type sign at rear and "Quattro" nameplates respectively 3B2 child seat anchor according to Australian requirements 3C7 3-point seat belt for center rear seat 3FE electric slide/tilt sunroof with sun screen/sunblind 3L3 manual height adjustment for front seats 3NZ rear seat bench unsplit, backrest split folding 3Q6 three rear headrests 3S0 without roof rails/roof load rack 3X0 without load-through provision 3Y0 without roll-up sun screen 4A0 without seat heater 4E4 rear door/tailgate release lever inside 4GP windshield tinted with sun band and viewing window for vehicle identification number 4K8 radio remote controlled central locking operated from inside, front and rear and separate trunk release 4KC side and rear windows tinted 4L2 dipping breakaway inside rear view mirror 4N0 standard dashboard 4P2 rear floor panel module, type 3 4R4 power windows with comfort operation andcircuit breaker 4UB airbag for NAR 4W0 without cassette and CD storage unit 4X3 side airbag front with curtain airbag 4ZE black moldings 5C1 body measures for increased safety requirements 5D2 carrier frequency 315 MHz 5K5 transit protective film (instead of paint preservative) 5RW outer right rear view mirror: convex, USlarge viewing field 5SG outer left rear view mirror: flat 5TD decorative aluminum inserts 6E6 center armrest front 6FB body-colored outer rear view mirror housings 6M4 load protection system 6PC leatherette hand brake lever handle 6Q2 leather gearshift knob/handle 6R0 selector lever cover 6SS luggage compartment floor covering 6U0 without additional seals outside 6V2 rear trim panel 6W3 license plate bracket front (small, NAR) 6XD outer rear view mirrors: powered, heated 7A0 without CD changer/CD player 7AL anti-theft alarm system, passenger compartment control, backup horn and towing protection 7B2 12-volt socket in luggage boot 7K0 without tire pressure warning light 7M0 plastic scuff plates in door apertures 7P1 power adjustable lumbar support in frontseats 7Q0 without navigation device 7QA without CD ROM 7X0 without park distance control 8BH ellipsoidal headlight for driving on the right, US design 8GR alternator 150A 8K0 without special low beam mode 8N4 windshield wiper intermittent control with potentiometer (four speeds) 8Q0 without headlight-range adjustment 8T1 cruise control system (CCS) 8TE rear fog light for USA 8X1 headlight washer system 8YN radio "symphony" for USA 8Z6 engine cooling system, type 2 9AK "Climatronic" with impact pressure control free of cfc 9M0 without auxiliary/parking heater 9NX without electronic logbook 9P1 seat belt warning light, electric contact in buckle 9Q2 multi-function indicator/on-board computer with check control 9T1 heated washer nozzles, front 9VD speaker (active) 9W0 w/o car phone preparation/installation A00 no self-collection A8U executive US equipment B0A component parts set without country-specific design requirement B34 legal requirements USA C00 operating permit, initial registration C1X alloy wheels 7 1/2J x 17 five-arm spider style, offset 45 E0A no special edition F0A no special purpose vehicle, standard equipment FA0 control of standard production FC0 without customized installation FM0 basic equipment variant FQ0 standard production wheels G0Q five-speed automatic transmission for four-wheel drive vehicle H8A tires 235/45 R 17 93Y J0R battery 380 A (80 Ah) K8B notchback L0L left-hand drive vehicle MW9 4-cyl. gasoline engine 1.8 L/125 kW 20V turbo base engine is T6V/T0L N0C leatherette seat covering NT1 transit coating (type 2) PPS Q1A standard front seats QE1 tray areas package 1 QH0 without voice control QQ1 additional lights (interior lighting) QV0 w/o TV reception/digital radio reception T0L components for base engine, unit 06B.G U1B instrument insert with mph speedometer, clock, tachometer and trip odometer V0A tires w/o specification of tire brand VC0 w/o remote-controlled garage door opener VR0 without impact protection measures
