Ответ: Извените если баян ) IPB WARNING [2] mysql_connect() [function.mysql-connect]: User pickupforum has already more than 'max_user_connections' active connections (Line: 131 of /ips_kernel/class_db_mysql.php) There appears to be an error with the database. You can try to refresh the page by clicking here. Error Returned SQL error: User pickupforum has already more than 'max_user_connections' active connections SQL error code: Date: Friday 19th of January 2007 10:01:32 PM We apologise for any inconvenience
Ответ: Извените если баян ) читал давно уже, гондоном подавилась дура, а парнишге надо было напалечник тада юзать, коль гандон велик на 10 размеров...почти убил девачку. печально...очень печально.
