Пробейте пожалуйста вин!!!
Тема в разделе "Выбор Audi с пробегом", создана пользователем mpv, 13 июл 2006.
  1. Airborn
    Airborn Живу я здесь
    30 июн 2005
    1.704
    Audi Q5 2.0d 2019
    Ответ: Пробейте пожалуйста вин!!!
    VIN Number WAUZZZ4BX2N073831;
    Sales type 4B202H;
    Exterior color Q5
    Roof color Q5
    Interior trim code LA;
    Engine code & No. ASN 17070;
    Transmission code FSA;
    Date of production 05.12.2001;
    Model year 2002;
    Код Опция
    1BE sports suspension/shock absorption
    9B0 without telepay device
    9Q2 multi-function indicator/on-board computer with check control
    0LW special plates/stickers/ safety certificates for Germany
    8T1 cruise control system (CCS)
    5MG decorative burr walnut inserts
    4X4 side airbag, front and rear with curtain airbag
    FQ0 standard production wheels
    3L5 electric seat adjustment for both front seats
    1YA without transmission shafts f. rear axle
    1C1 antifreeze up to -25 degree celsius tolerance up to -30 degree C
    0F2 fuel system for carburetor gasoline engine
    L0L left-hand drive vehicle
    8TC rear fog light for driving on the right
    QH0 without voice control
    7P1 power adjustable lumbar support in frontseats
    1Z0 initial standard fuel filling
    B01 type approval Germany
    8ED bi-functional headlight with gas discharge lamp, for driving on the right
    7A2 CD changer
    Q1E RECARO sports seats, front
    0N6 rear axle with reduced tread
    VX0 without hands-free system
    7X0 without park distance control
    2WA without additional tires
    QA0 without child seat
    B0A component parts set without country-specific design requirement
    FC1 customized installation
    1D0 without towing attachment
    2A4 delivery equipment for shipment (transitcoating) with thick seat cover
    1KD disc brakes, rear
    7AH electronic vehicle immobilization devicewith alarm system, passenger compartmentcontrol and backup horn
    G0Z variable gearing ratio
    T15 components for base engine, unit 06C.B (aluminum)
    0G7 Tiptronic
    8N4 windshield wiper intermittent control with potentiometer (four speeds)
    D2H 6-cyl. gasoline engine 3.0 L/162 kW 30V V6 base engine is T15
    7Q2 navigation system with color screen
    1SA without additional engine guard
    6SS luggage compartment floor covering
    6E3 center armrest front
    0VC information kit in German
    0GG emissions concept EU 4
    VY0 without danger alarm system
    4K4 radio remote controlled central locking operated from inside and separate trunk release
    VJ1 reinforced bumpers
    2B0 without additional exterior noise suppression
    7QB CD ROM (Germany)
    J0L battery 340 A (70 Ah)
    6M1 tie down straps
    1T3 first aid kit and warning triangle
    1E1 activated carbon canister
    0W1 label for central electric German-speaking countries
    E0A no special edition
    4ZB bright moldings
    1LG disc brakes, front
    3V0 without child bench seat
    4KC side and rear windows tinted
    5A5 trunk lining, with stowage trays
    3FR electric sliding/pop-up solar sunroof with automatic pre-selection
    VC0 w/o remote-controlled garage door opener
    6U0 without additional seals outside
    4L2 dipping breakaway inside rear view mirror
    3GA without cargo area
    8GR alternator 150A
    7K0 without tire pressure warning light
    6FB body-colored outer rear view mirror housings
    3NZ rear seat bench unsplit, backrest split folding
    2C5 axial and vertical adjustable steering column
    9M0 without auxiliary/parking heater
    4E0 tailgate/trunk lid unlocking from outside
    1EX special identification plate for EC
    2Z0 deletion of model designation
    6V1 rear trim panel (ECE)
    1N3 speed-related variable steering assist (Servotronic)
    1MU leather trimmed sports steering wheel for airbag system with Tiptronic
    NT0 transit coating (type 1)
    H8A tires 235/45 R 17 93Y
    8X1 headlight washer system
    3HA without leather parts scope
    1G3 alloy spare wheel with original equipment tires
    5C0 without special body measures
    3X1 load-through provision with ski bag
    8Q3 automatic headlight-range adjustment dynamic (self-adjusting while driving)
    7E0 w/o heat accumulator/auxiliary heating
    C18 operating permit, alteration 18
    8AY radio/navigation system
    6W5 front license plate bracket
    5K1 paint preservative (wax)
    0YD weight category rear axle weight range 4
    1VH installation parts for six-cylinder engine
    4N0 standard dashboard
    4UE airbag f. driver a. front seat passenger
    3B0 without additional child seat anchor
    2T1 double-sized standard (DIN)
    0JJ weight category front axle weight range 9
    7M1 scuff plates in door apertures with metal inserts
    3Q6 three rear headrests
    A00 no self-collection
    F0A no special purpose vehicle, standard equipment
    K8B notchback
    5D1 carrier frequency 433.92 MHz
    5RU outer right rear view mirror: convex (large viewing field)
    9NX without electronic logbook
    3Y5 electrically operated roll-up sun screenfor rear window and mechanically operated for side windows
    C1X alloy wheels 7 1/2J x 17 five-arm spider style, offset 45
    6PC leatherette hand brake lever handle
    U2B instrument insert with km/h speedometer,radio-controlled clock, tachometer, tripodometer and additional instruments
    1WG transmission shaft w/ 88mm in diameter
    9W0 w/o car phone preparation/installation
    8K0 without special low beam mode
    8Z5 engine cooling system, type 1
    5SL outer left rear view mirror: non-spherical
    1X0 front wheel drive
    4GH windshield tinted with windshield sunshield
    6Q2 leather gearshift knob/handle
    3C7 3-point seat belt for center rear seat
    1PC wheel bolts with anti-theft protection (unlockable)
    6XE outer rear view mirrors: powered, heatedelectrically foldable
    4W0 without cassette and CD storage unit
    9P0 without seat belt warning light
    5E6 sill top with door cover
    3CA without partition
    FA0 control of standard production
    V0A tires w/o specification of tire brand
    8RY speakers with BOSE sound
    A8S standard equipment
    0ST labels/plates in German and French
    0DS installation differentiation for build status of vehicle class 4B0 (AUDI)
    3S0 without roof rails/roof load rack
    QV0 w/o TV reception/digital radio reception
    4A3 seat heater for front seats separately controlled
    N1H leather seat covering
    2G1 insert for the filling up of unleaded fuel
    6R0 selector lever cover
    9AK Climatronic with impact pressure control free of cfc
    Нераспознанные коды
    RLB PS2 PRV PLD PSV PDW PNB P18 PWF PX4
  2. mr_noel
    mr_noel Новичок
    30 апр 2006
    44
    Спасибо!!!!!
  3. Airborn
    30 июн 2005
    1.704
    Audi Q5 2.0d 2019
    #43 Airborn, 20 июл 2006
    самый мудрый да? :rzunimagu
  4. Airborn
    30 июн 2005
    1.704
    Audi Q5 2.0d 2019
    #44 Airborn, 20 июл 2006
    исправил
  5. Захар
    Захар Нас тупило утро...
    11 ноя 2004
    4.617
    White Earth Dreams
    типа того :rzunimagu
  6. Templar
    Templar Участник форума
    6 апр 2006
    319
    А6C5 3.0Q
    Пробейте и мой если не трудна! ЗАранее благодарю!!
    A4Avant 2000г WAUZZZ8DZ1A027826
  7. Airborn
    30 июн 2005
    1.704
    Audi Q5 2.0d 2019
    VIN Number WAUZZZ8DZ1A027826;
    Sales type 8D50C4;
    Exterior color E8
    Roof color E8
    Interior trim code EB;
    Engine code & No. AVV 3339;
    Transmission code DWA;
    Date of production 11.07.2000;
    Model year 2001;
    Расшифровка кодов комплектации
    Код Опция
    9Q0 without multi-function indicator/ on-board computer
    4X1 side airbag front
    0TD front and rear floor mats
    8T0 without cruise control system (CCS)
    3L1 manual height adjustment for left front seat
    6RA dashboard and door trim panel one-piece, single color
    9Y1 outdoor temperature gage
    7A0 without CD changer/CD player
    Q1A standard front seats
    G0C 5-speed manual transmission
    7AA electronic vehicle immobilization device
    FC0 without customized installation
    ME9 4-cyl. gasoline engine 1.8 L/92 kW 20V with multi-point injection base engine is T0V/T5Z/T64/T6W
    2A5 delivery equipment (transit coating) with thin seat cover
    0G1 gearshift lever
    4R2 power windows front, mechanical window regulators rear
    8UC radio "chorus"
    7Q0 without navigation device
    2PG steering wheel
    0GE emissions concept EU 3
    3FA without roof insert (standard roof)
    9ZF preparation for cellular phone with hands-free speaking system
    7QA without CD ROM
    6M0 without tie down straps/net/pocket
    B99 type approval EC
    4ZE black moldings
    H6S tires 195/65 R 15 V
    8GL alternator 120A
    9T1 heated washer nozzles, front
    4SB vanity mirror left
    1LZ front disc brakes, standard ventilation
    7CA without label for radio remote control
    6N0 without mud flaps
    J1P battery 220 A (44 Ah)
    8WB front fog lights
    N5G fabric seat covering (not specified yet)
    2K1 reinforced bumpers
    5J0 without rear spoiler
    4M0 without cup holder
    4TB vanity mirror right
    8X0 without headlight washer system
    3X0 without load-through provision
    8Q1 headlight-range adjustment
    C15 operating permit, alteration 15
    5K0 without paint preservative
    1VG installation parts for four-cylinder engine
    C8N alloy wheels 6J x 15 style not designated; 4B0 601 025 L offset 45
    0YE weight category rear axle weight range 5
    0JE weight category front axle weight range 5
    2T0 without double-sized standard (DIN)
    5RQ outer right rear view mirror: convex
    K8D Station Wagon Variant/Avant
    0K0 without alternative drive module
    3Y0 without roll-up sun screen
    6PA plastic hand brake lever handle
    U2A instrument insert with km/h speedometer,radio-controlled clock, tachometer and trip odometer
    1WC transmission shaft w/ 108mm in diameter
    8JH ellipsoidal headlight for driving on the right
    1PA standard wheel bolts
    6Q1 plastic gearshift knob/handle
    6XD outer rear view mirrors: powered, heated
    1AC anti-lock brake system (ABS)
    0L2 electric throttle actuation
    5E1 without sill top with door cover
    8RN eight speakers (active)
    3CB removable net partition
    8KB catalytic converter warning light
    8S4 two reading lights front, two rear
    T5Z components for base engine, unit 058.B
    4P0 rear floor panel module, type 1
    5TH decorative aluminum inserts "points"
    3S2 black roof rails
    0DY installation differentiation for build status of vehicle class B5 (AUDI) unit components
    9X6 heated door lock cylinder left with micro switch
    6R1 leatherette gearshift boot
    1BA standard suspension/shock absorption
    Нераспознанные коды
    WM5 PSV PFA PW1 RBL
    Введите коды комплектации
  8. gar
    gar Bad e-mail
    5 июл 2006
    36
    Audi A4/8E 2.0 02г
    Пробейте, пожалуйста ВИН:
    WAUZZZ8E92A256892
    заранее благодарен.
  9. Airborn
    30 июн 2005
    1.704
    Audi Q5 2.0d 2019
    VIN: WAUZZZ8E92A256892
    Код модели: 8E20B4 ()
    Дата выпуска: 06.03.2002
    Модельный год: 2002
    Код и номер двигателя: ALT 079783
    Код КПП: FJP
    Комбинация цветов интерьера: LA
    Комбинация цветов кузова: A2
    Цвет крыши: A2
    Комплектация автомобиля (код и наименование):
    0CS vehicle class differentiation 8E0
    0G1 gearshift lever
    0JF weight category front axle weight range 6
    0LW special plates/stickers/safety certificates for Germany
    0YG weight category rear axle weight range 7
    1LB disc brakes, front
    1MR leather steering wheel
    1N1 power steering
    1W0 without refrigerator/glove compartment cooling system
    1WG transmission shaft w/88mm in diameter
    2KR labels/plates in English and German
    2V1 dust and pollen filter
    2Z7 type sign and company logo without displacement data
    3C1 static lap belt, center rear
    3DA winter tires 195/65 R 15 H with steel wheel 6 1/2J x 15, offset 33 with full wheel cover
    3L3 manual height adjustment for front seats
    3ND rear seat bench/backrest, unfolding
    3Q1 rear headrests
    4P2 rear floor panel module, type 3
    4R5 power windows with comfort operation andcircuit breaker, mechanical window regulators rear
    4X3 side airbag front with curtain airbag
    4ZE black moldings
    5K5 transit protective film (instead of paint preservative)
    5MA decorative inserts
    6E0 without center armrest front
    6R2 leather gearshift boot
    7B0 without socket
    7M0 plastic scuff plates in door apertures
    7P0 without lumbar support in front and rear seats
    7QA without CD ROM
    7X2 ultrasonic park distance control front and rear
    8GL alternator 120A
    8UC radio "chorus"
    9AK "Climatronic" with impact pressure control free of cfc
    9VD speaker (active)
    C03 operating permit, alteration 3
    CA1 forged alloy wheels 7J x 16
    FM0 basic equipment variant
    H6U tires 205/55 R 16 91W
    J1L battery 280 A (60 Ah)
    K8B notchback
    MW2 4-cyl. gasoline engine 2.0 L/96 kW 20V with multi-point injection, EU 4 base engine is T0F
    N3A fabric seat covering
    P15
    PI3
    PRK
    PSV
    QE0 without tray areas package/box
    QQ0 without add. lights (interior lighting)
    T0F components for base engine, unit 06B.E (aluminum)
    VR0 without impact protection measures
  10. yuleon
    yuleon Новичок
    4 июл 2006
    5
    Audi A4 1,8T Quattro 95г.
    подскажи прогу?!
  11. yuleon
    yuleon Новичок
    4 июл 2006
    5
    Airborn - че за перебор англицких символов?
    по вину? вот если бы по вину выдавались чертежи и маркировка деталей?! вот это да, давай найдем где нть, мож на варезниках опять каких нибудь? или есть свободные открытые источники, но я еще не прочел ентого.
  12. Airborn
    30 июн 2005
    1.704
    Audi Q5 2.0d 2019
    ETKA, или http://www.vw-club.ru/vw/vin/
  13. Garik119
    Garik119 Участник форума
    11 фев 2005
    382
    А4/8К 1,8Т FL 2013
    VIN: WAUZZZ8DZXA218124
    Код модели: 8D2064 ()
    Дата выпуска: 11.02.1999
    Модельный год: 1999
    Код и номер двигателя: AHL 355341
    Код КПП: DVP
    Комбинация цветов интерьера: BN
    Комбинация цветов кузова: 5B
    Цвет крыши: 5B
    0G1 gearshift lever
    0JC weight category front axle weight range 3
    0L0 mechanical throttle actuation
    0YC weight category rear axle weight range 3
    1S7 tool kit and aluminum jack
    1WB transmission shaft w/100mm in diameter
    2PG steering wheel
    2Z1 type sign at rear and "Quattro" nameplates respectively
    3Q1 rear headrests
    4A0 without seat heater
    4F1 central locking system
    4LA without controls
    4ZE black moldings
    5A4 trunk lining (design 1)
    5D0 without carrier frequency
    5MF decorative aluminum inserts "strips quartz"
    6RB dashboard and door trim panel multi-piece, single-color, multi-colored
    7QA without CD ROM
    8CC speedometer sensor without seal (electronic speedometer sensor)
    8GD alternator 90A
    8UC radio "chorus"
    9Q0 without multi-function indicator/on-board computer
    C12 operating permit, alteration 12
    K8B notchback
    M4T 4-cylinder gasoline engine 1.6 L/74 kW w/multi-point injection a. MVEG 2/EU 3Dbase engine is T6U
    N4G fabric seat covering "Basic"
    PH5
    PW1
    RBL
    T6U components for base engine, unit 06B.1
    U1A instrument insert with km/h speedometer,clock, tachometer and trip odometer
    WM1
  14. dago
    dago Живу я здесь
    17 июл 2006
    1.062
    Ауди A-6/45 2,5TDI, Mitsubishi Pajero IIдо этого VW Passat b3 1.8 ABS/ A 80 b3 1.8 PM/ A 80 b-4 2.0 ABT
    И мне пожалуйста!
    WAUZZZ4AZTN050983
  15. mijgan
    mijgan Bad e-mail
    25 июн 2005
    52
    Audi A6 ALF 2.4 МКПП 99г.
    VIN: WAUZZZ4AZTN050983
    Код модели: 4A20YC ()
    Дата выпуска: 15.12.1995
    Модельный год: 1996
    Код и номер двигателя: AEL 025287
    Код КПП: ARX
    Комбинация цветов интерьера: HE
    Комбинация цветов кузова: X6
    Цвет крыши: X6
    0DT installation differentiation for build status of vehicle class C (AUDI) unit components
    0EC installation differentiation for transmission C90 vehicle components
    0F3 fuel system for diesel engine
    0G1 gearshift lever
    0LU special plates/stickers/safety certificates for Belgium
    0MA without label for starting an automatic
    0SB labels/plates in German
    0TC front floor mats
    0VH information kit in Dutch
    1E0 without activated charcoal canister
    1EJ special identification plate
    1G2 steel spare wheel with original equipment tires
    1N1 power steering
    1T2 warning triangle
    1VB installation parts for five-cylinder engine
    1Z1 increase in initial standard fuel filling by 4 liters
    2B2 additional exterior noise suppression
    2CA without central hydraulic system
    2G0 without insert for the filling up of fuel
    2L0 without lower fuel tank protection
    2PG steering wheel
    2TC radiator grille and bumper for TDI vehicles
    3AF outer right rear view mirror: convex, powered, heated
    3BS outer left rear view mirror: non-spherical, powered, heated
    3C3 lap belt with retractor for the center rear seat
    3FQ electric sliding/pop-up sun roof with automatic pre-selection
    3J1 height-adjustable headrests for front seats
    3N0 without stowage box in luggage boot
    3Q5 rear headrests
    3YB door pockets, front
    3ZB 3-point seat belts, outer rear with ECE label
    4TD right vanity mirror illuminated
    4U0 without luggage nets/pockets on backrests
    4UC airbag for driver
    4ZB bright moldings
    5H2 tailgate lining
    5MD decorative aluminum inserts
    6C0 standard door window seal
    6D1 center armrest rear
    6E4 WITH COLLAPSABLE CENTRE ARMREST FRONT, WITH BACK SUPPORT
    6EA without additional side body covers (stone guard)
    6G1 defroster nozzles for side windows snap shut
    6KG radiator grille
    6T0 without interior light in foot area
    7E6 electric auxiliary air heater
    8AV without radio, with loudspeaker connections
    8F2 side turn signal lights
    8FA without second battery
    8G0 without antenna cable for radio system
    8GL alternator 120A
    8KA w/o catalytic converter warning light
    8L4 window antenna
    8LB additional instruments (voltage, oil pressure and temperature)
    8NA without parking light warning light
    8R0 without center high-mounted stop light
    8RM eight loudspeakers (passive)
    8U0 without additional instruments for distance measurement
    8Y1 two-tone horn
    8Z2 engine cooling system with heavy-duty fan and radiator
    9A0 without taxi alarm system
    9BA w/o additional electric safety package
    9ED wire assembly for five-cylinder diesel engine
    9F0 without sound combination for rotating emergency light and radio antenna preparation
    9G0 without preparation for roof attachments
    9HD malfunction display (with light)
    9J0 without supertone system and tone sequence control
    9PB windshield wiper arms/blades with additional guide vanes
    9R0 WITHOUT CONTROL CHECK PACKAGE
    9S0 WITHOUT PROVISION FOR RADIO SET
    9SA WITHOUT PROGRAMMING PLUG
    9T0 without heated washer nozzles
    9X4 without heated door lock cylinder with micro switch
    B02 type approval Belgium
    C00 operating permit, initial registration
    C0V steel wheels 6J x 15 offset 45 (five-hole)
    G0K 6-speed manual transmission
    H3E tires 195/65 R 15 V (black)
    J1A battery 380 A (64 Ah)
    K8B notchback
    M49 5-cyl. turbo diesel engine 2.5 L/103 kW with MVEG 2 base engine is T4E
    N4R Cloth Seat cover "Quadrat"
    PH5
    T4E components for base engine, unit 046.B
    U0C instrument insert with tachometer clock and km/h speedometer
    WSH
  16. micha088
    micha088 Старожил
    12 дек 2004
    21.543
    Ласка
    #56 micha088, 24 июл 2006
    Буду очень признателен WAUZZZ8DZXA061229
  17. Airborn
    30 июн 2005
    1.704
    Audi Q5 2.0d 2019
    Исправь вин-код, он неправильный :hi:
  18. micha088
    micha088 Старожил
    12 дек 2004
    21.543
    Ласка
    С твоей подсказки залез сам и посмотрел но очень многое так и не понял. Где или кто все это может расшифровать.
  19. Коля Герасимов
    Коля Герасимов Живу я здесь
    11 май 2004
    1.501
    Трёхлитровая японк
    Задавай конкретные вопросы, поробуем перевести (номер краски не расшифрую, но с остальным попробуем).
  20. Airborn
    30 июн 2005
    1.704
    Audi Q5 2.0d 2019
    дык они и выдаюЦЦА, "только нэ здэсь (с)"
