A3 Concept или наброски к новой А3
Тема в разделе "A3", создана пользователем Lost, 1 мар 2011.
  1. Lost
    Lost Старожил
    1 янв 2003
    8.606
    Эска - с*ка зло
    Drivetrain
    The A3 concept has a five-cylinder engine under the hood that combines the Audi technologies of turbocharging and FSI gasoline direction injection. It develops a hefty 300 kW (408 hp) from a displacement of 2.5 liters. Its peak torque of 500 Nm (368.78 lb-ft) is available over a broad rev range between 1,600 and 5,300 rpm.
    The five-cylinder powerplant unleashes a rousing soundscape – its typical sound pattern calls to mind the Audi sound of the 1980s and the huge motorsport successes of that period. Its performance is a complete homage to tradition: The A3 concept catapults from a dead stop to 100 km/h (62.14 mph) in 4.1 seconds, and its electronically governed top speed of 250 km/h (155.34 mph) is merely the official figure.
    In terms of fuel consumption, the four-seater requires just 9.1 liters of fuel per 100 km (25.85 US mpg) and emits 212 grams CO2 per km (341.18 g/mile). A regulated oil pump, the intelligent Audi thermo-management system and a energy recovery system – technologies from the brand’s modular efficiency platform – all contribute to this high efficiency.
    A compact seven-speed S tronic serves as the transmission. It comprises two transmission structures, which are operated by two clutches. Gears are alternately shifted by the two clutches – at lightning speed, comfortably, and without any perceptible interruption of traction.
    The driver can operate the seven-speed S tronic in one automatic mode and one manual mode, using the paddles on the steering wheel to shift gears manually. Elegant touch control buttons on the center tunnel console are used to select drive positions R, N and D. These are backlit in red when it gets dark. Drive position P is automatically engaged when the electric parking brake is applied. The launch control system manages the sprint from a dead stop, furnishing explosive turbo power with minimal tire slip.
    Power is effortlessly transmitted to the road via quattro permanent all-wheel drive. Its centerpiece is an electronically controlled multi-plate clutch at the end of the propeller shaft. When slip occurs at one of the axles, the clutch redirects the majority of the torque input to the wheels with the better grip.
  2. grust
    grust Живу я здесь
    27 сен 2005
    1.564
    A4 2.0, 2007
    ниче так)
    размерами как 8Е, наверное, будет.
  3. regniws
    regniws Завсегдатай
    12 мар 2009
    526
    A3 1.8T -> хх С200
    #3 regniws, 1 мар 2011
    Что нравится:
    - вид с боку, пологий капот и с-лайновский спойлер на жопе - узнается ауди. Нра
    - решетка радиатора - будет точно не такой ярковыраженной как на рендерах. А то, что представляется, как я ее подтянут - нравится.
    - оптика, на рендерах она вся ледовская, уверен, что в не ледовском варианте будет очень современно смотрется. Поворотники - очень нравится.
    - задний бампер, крышка багажника - очень здорово. Нравится
    - зеркала очень приятные. Неоднозначно. Но - нравится. Да! Главное, чтобы карбон в опции убрали ))
    - раскраска салона в рендере - нравится
    - место под КПП - нравится, как организовано
    - подставки под айпад в подголовниках - супер! Для ребенка в дальней дороге просто чудо.
    - наличие на передней правой двери кнопки закрытия. АЛИЛУЯ!!
    - слайн руль с высокими подрулевыми, приборка - да, приятно очень.
    О грустном:
    - на этих дисках не смотрится никак. Боюсь что при завышении подвески + уменьшении размеров дисков будет еще хуже.
    - ручки дверей. wtf?
    - везденапичканный карбон
    - крутюшка света
    - дефлекторы воздуха
    - ну и главный фейл - центральная консоль. Это ппц! это просто трэш! + выезжающий дисплей. Это просто слов нет.
    непонятно:
    Останется ли это концептом? если не останется, то будут тока с этим движком продавать? Эх.
    С другой стороны, понятно, в каком направлении двигается А3. Думаю, что А3 и А3 Спортзад будут примрно таковыми за вычетом жопы.
  4. Кенгуру
    Кенгуру Живу я здесь
    20 янв 2005
    1.558
    Prado+R1200GS
    #4 Кенгуру, 1 мар 2011
    Морда на Фокус похожа.
  5. regniws
    regniws Завсегдатай
    12 мар 2009
    526
    A3 1.8T -> хх С200
    смешная шутка.
    где именно похожа-то?
  6. udg
    udg Новичок
    6 фев 2011
    42
    Golf 6
    А мне не очень нравится... Не люблю я седаны... Зачем вообще плодить седаны А4 уже не хватает?
  7. regniws
    regniws Завсегдатай
    12 мар 2009
    526
    A3 1.8T -> хх С200
    Так же зачем нужен пассат и джетта.
    Разница в длине с а4 30 см. Очень прилично.
    Тем более кузов хэтчбека точно останется. Просто теперь три варианта, вероятно, будет.
  8. Yurcha
    Yurcha Участник форума
    18 мар 2008
    285
    A4
    мне нравится...
    но А3 "не вижу"
  9. regniws
    regniws Завсегдатай
    12 мар 2009
    526
    A3 1.8T -> хх С200
  10. udg
    udg Новичок
    6 фев 2011
    42
    Golf 6
    Согласен.
  11. udg
    udg Новичок
    6 фев 2011
    42
    Golf 6
    #11 udg, 1 мар 2011
    Если хэтч останется тогда хорошо... А вот если нет-тогда будет плохо:shock:
  12. regniws
    regniws Завсегдатай
    12 мар 2009
    526
    A3 1.8T -> хх С200
    Хэтч по-любому останется. Это можно и не сомневаться.
    Сейчас они показали концепт нового кузова, который несколько "подуляжеться" и будет не таким вопиющим.
    А так же показали морду новой А3, хэтчбека.
    В целом все понятно.
  13. regniws
    regniws Завсегдатай
    12 мар 2009
    526
    A3 1.8T -> хх С200
    Это А1 переросток.
  14. Yurcha
    18 мар 2008
    285
    A4
    по мне - А4 недоросток :)
  15. regniws
    regniws Завсегдатай
    12 мар 2009
    526
    A3 1.8T -> хх С200
    И что вы в ней видите от а4?
  16. Yurcha
    18 мар 2008
    285
    A4
    А1 и А3 я в ней точно не вижу :)
  17. regniws
    regniws Завсегдатай
    12 мар 2009
    526
    A3 1.8T -> хх С200
    Сравните:
  18. Yurcha
    18 мар 2008
    285
    A4
    К сожалению, не могу вставить фотографии...
  19. viza
    viza Участник форума
    5 фев 2008
    479
    А3 2.0 FSI
    описание от RS3, а картинка - новый кузов
  20. Chertenok
    Chertenok Старожил
    9 июл 2009
    5.067
    A5 2019
    ну все, коплю бабосик :sluni:
