провалы и глохнет подскажите куда копать!! машина иногда глохнет на ходу или на холостых! бывают провалы!! обороты иногда плавают!!! вот такие ошибки::::::Thursday,11,July,2013,11:44:47:32264 VCDS Version: Release 11.11.3 Data version: 20120401 -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 8E - Audi A4 B6/B7 Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67 69 75 76 77 VIN: WAUAF68E55A436119 Mileage: 168920km/104962miles ------------------------------------------------------------------------------- Address 01: Engine Labels: 06F-907-115-AXX.lbl Part No SW: 8E0 910 115 B HW: 8E0 907 115 C Component: 2.0l R4/4V TFSI 0120 Revision: --H02--- Serial number: Coding: 0104010A02070120 Shop #: WSC 05146 444 87954 VCID: 2045FE59F3D8C29 5 Faults Found: 004243 - Bank 1; Fuel Measuring System 2 P1093 - 008 - Malfunction - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 0 Fault Frequency: 4 Mileage: 168264 km Time Indication: 0 Freeze Frame: RPM: 1754 /min Load: 10.6 % Speed: 83.0 km/h Temperature: 85.0°C Temperature: 29.0°C Absolute Pres.: 990.0 mbar Voltage: 13.716 V 008504 - Accelerator Position Sensors (G79) / (G185) P2138 - 008 - Implausible Correlation - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 0 Fault Frequency: 3 Mileage: 168489 km Time Indication: 0 Freeze Frame: RPM: 0 /min Load: 0.0 % Speed: 0.0 km/h Temperature: 108.0°C Temperature: 78.0°C Absolute Pres.: 980.0 mbar Voltage: 12.192 V 012555 - Low Pressure Fuel regulation P310B - 004 - Fuel Pressure Outside Specification - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 0 Fault Frequency: 1 Mileage: 168731 km Time Indication: 0 Freeze Frame: RPM: 775 /min Load: 32.1 % Speed: 0.0 km/h Temperature: 97.0°C Temperature: 66.0°C Absolute Pres.: 1000.0 mbar Voltage: 12.954 V 012902 - Oxygen (Lambda) Sensor B1 S1 P3266 - 008 - Internal Resistance Implausible - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 0 Fault Frequency: 1 Mileage: 168780 km Time Indication: 0 Freeze Frame: RPM: 915 /min Load: 42.7 % Speed: 3.0 km/h Temperature: 72.0°C Temperature: 47.0°C Absolute Pres.: 1000.0 mbar Voltage: 13.208 V 000304 - Oxygen (Lambda) Sensor B1 S1 P0130 - 001 - Malfunction in Circuit - Intermittent Freeze Frame: Fault Status: 00100001 Fault Priority: 0 Fault Frequency: 1 Mileage: 168780 km Time Indication: 0 Freeze Frame: RPM: 915 /min Load: 42.7 % Speed: 3.0 km/h Temperature: 72.0°C Temperature: 47.0°C Absolute Pres.: 1000.0 mbar Voltage: 13.208 V Readiness: 0000 0000
