a4 2.0 tfsi quattro 2006 собственно не едет. бумер 325хи уходит вперед. хотя не должен. ошибки: Friday,12,October,2012,23:15:37:10074 VCDS Version: Release 11.11.2 Address 01: Engine Labels: 06F-907-115-AXX.lbl Control Module Part Number: 8E0 910 115 L HW: 8E0 907 115 D Component and/or Version: Software Coding: Work Shop Code: WSC 00000 935 65080 VCID: 2A5F069B85E4083 4 Faults Found 000665 - Boost Pressure Regulation P0299 - 002 - Control Range Not Reached Freeze Frame Fault Status: 01100010 Fault Priority: 0 Fault Frequency: 1 Mileage: 108272 km Time Indication: 0 Freeze Frame Raw, Form. N/A: 000 000 093 Load: 67.4 % Speed: 38.0 km/h Raw, Form. N/A: 000 000 000 Raw, Form. N/A: 000 000 000 Raw, Form. N/A: 000 250 098 Voltage: 13.462 V 000313 - Oxygen (Lambda) Sensor B1 S2 P0139 - 002 - Response too Slow - Intermittent Freeze Frame Fault Status: 00100010 Fault Priority: 0 Fault Frequency: 1 Mileage: 108274 km Time Indication: 0 Freeze Frame Raw, Form. N/A: 000 000 014 Load: 11.4 % Speed: 74.0 km/h Temperature: 99.0�C Temperature: 39.0�C Absolute Pres.: 0.0 mbar Raw, Form. N/A: 000 000 000 Raw, Form. N/A: 000 000 057 004372 - Oxygen (Lambda) Sensor; B1 S2 P1114 - 008 - Internal Resistance too High - Intermittent Freeze Frame Fault Status: 00101000 Fault Priority: 0 Fault Frequency: 1 Mileage: 108274 km Time Indication: 0 Freeze Frame Raw, Form. N/A: 000 000 014 Load: 11.8 % Speed: 74.0 km/h Raw, Form. N/A: 000 000 000 Raw, Form. N/A: 000 000 000 Raw, Form. N/A: 000 250 098 Voltage: 13.589 V 008801 - Boost Pressure Control Valve (N249) P2261 - 008 - Mechanical Malfunction Freeze Frame Fault Status: 01101000 Fault Priority: 0 Fault Frequency: 2 Mileage: 108304 km Time Indication: 0 Freeze Frame Raw, Form. N/A: 000 000 069 Load: 10.2 % Speed: 112.0 km/h Raw, Form. N/A: 000 000 000 Raw, Form. N/A: 000 000 000 Raw, Form. N/A: 000 250 099 Voltage: 13.843 V Readiness: 0000 0001 стоит тестпайп вместо ката. толкатель и PCV меняны. Кто сталкивался, что делать дальше?
