Тема в разделе "Ремонт Ауди", создана пользователем GrayCep, 26 фев 2009.
  1. Udgin0069
    Udgin0069 Живу я здесь
    23 янв 2012
    3.747
    A4 B8 2.0T
    Всем привет !
    A4 B8 2.0T 2008 год
    Замигал чек, буквально на 3 секунды, далее все норм. Бензин уже на лампочке был, заехал на заправку залил 98-го хорошего
    Приехал домой, проверил на ошибки :
    Address 01: Engine (MSTR-CDNB) Labels: 06H-907-115-CAB.clb
    Part No SW: 8K2 907 115 Q HW: 8K2 907 115 D
    Component: 2.0l R4/4V TF H12 0003
    Revision: E1H12---
    Coding: 0104000C02070160
    Shop #: WSC 06325 000 00000
    ASAM Dataset: EV_ECM20TFS8K2907115Q A01005
    ROD: EV_ECM20TFS8K2907115Q.rod
    VCID: 3D753DC71DF7
    6 Faults Found:
    4695 - Function Restriction due to Received Malfunction Value
    U1113 00 [032] - Short to Ground
    4698 - Function Restriction due to Received Malfunction Value
    U1113 00 [032] - Open or Short to Plus
    4699 - Function Restriction due to Received Malfunction Value
    U1113 00 [032] - Open Circuit
    4063 - Cylinder 4: Misfire Detected
    P0304 00 [096] - Cannot Be Tested at this Time
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 84900 km
    Date: 2012.06.26
    Time: 18:20:06
    4051 - Random/Multiple Cylinder Misfire Detected
    P0300 00 [096] - Mechanical Failure
    4201 - Fuel Level too Low
    P1250 00 [109] - Open or Short to Ground
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Mileage: 84900 km
    Date: 2012.06.26
    Time: 18:20:06
    Readiness: 0000 0000
    Address 02: Auto Trans (J217) Labels: 0AW-927-156.clb
    Part No SW: 8K0 927 155 AA HW: 0AW 927 156 G
    Component: 0AW 20TFSIRdW H01 0006
    Revision: --H01--- Serial number: 0000000142
    Coding: 000001
    ASAM Dataset: EV_TCMVL381 A02006
    ROD: EV_TCMVL381_AU48.rod
    VCID: 72EFDEFB1429
    2 Faults Found:
    2264 - No Communication with Engine Control Module (SAE:ECM/PCM)
    U0100 00 [032] - Implausible Signal
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 0
    Fault Frequency: 27
    Reset counter: 32
    Mileage: 0 km
    Date: 2000.00.00
    Time: 00:00:00
    7066 - No Communication with Engine Control Module (SAE:ECM/PCM)
    U0100 00 [032] - Open or Short to Plus
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 27
    Reset counter: 32
    Mileage: 0 km
    Date: 2000.00.00
    Time: 00:00:00
    Всю эту радость стер, поездил немного: в динамике провалов нет, ошибок не выдает.
    Свечи/катушки из-за плохого бенза ?
    Спасибо заранее.
    А еще, ранее вот такая радость была:
    Address 08: Auto HVAC (J255) Labels: Redir Fail!
    Part No SW: 8T1 820 043 AC HW: 8T1 820 043 AC
    Component: KLIMA 3 ZONEN H06 0140
    Revision: C1000000 Serial number: 0131.07.081447
    Coding: 64000000
    VCID: 72EFDEFB1429
    2 Faults Found:
    00457 - Control Module for Network (J519)
    013 - Check DTC Memory - Intermittent
    Freeze Frame:
    Fault Status: 00101101
    Fault Priority: 6
    Fault Frequency: 8
    Reset counter: 223
    Mileage: 83656 km
    Time Indication: 0
    Date: 2012.06.06
    Time: 07:34:16
    00256 - A/C Pressure/Temperature Sensor (G395)
    008 - Implausible Signal - Intermittent
    Freeze Frame:
    Fault Status: 00101000
    Fault Priority: 7
    Fault Frequency: 8
    Reset counter: 223
    Mileage: 83656 km
    Time Indication: 0
    Date: 2012.06.06
    Time: 07:34:17
    Freeze Frame:
    Temperature: 17.0∞C
    Климат работает и работал, ошибки стер больше не появляются.
    Спасибо.
  2. melkon
    27.090
    Tuareg NF 3.0TDI на пневме.
    Вот группы измерений из VAS по 57 блоку (Гибридный ТВ-тюнер) . Что такое "фантомное напряжение " я не в курсе ... Телемастер из меня не ахти :cry:
  3. 052
    052 Водолей
    24 янв 2011
    6.388
    bmx
    Увалил епром щитка. Надо искать подобный дамп, править в нём логин, пересчитывать контрольную сумму и перезаливать. Из доступного есть только
    1J0 920 820 В
    Компонент: A4-KOMBIINSTR. VDO V14.
  4. agricaev
    agricaev Живу я здесь
    6 мар 2011
    1.799
    была Allroad 4F C6
    Спасибо. Значит зря я напрягался по 8 группе. Осталось разобраться, почему фантомное напряжение на 4 антенне = 0, а на остальных антеннах 12 вольт и что это вообще такое.
    А информация по измеряемым величинам где то есть в открытом доступе? Чтоб все сразу качнуть и не бес покоить людей по ерунде?
  5. 052
    052 Водолей
    24 янв 2011
    6.388
    bmx
    #7245 052, 26 июн 2012
    Может просто проверить предохраны sd6 & 16. Вот инфа
  6. волчек
    волчек Bad e-mail
    5 сен 2008
    636
    А4 B6 1,8TQ МТ 250
    комрады, дайте распиновку - оченама надо :shock:
  7. 052
    052 Водолей
    24 янв 2011
    6.388
    bmx
    #7247 052, 26 июн 2012
    Может и хана .Трудный вопрос, проводку звони-провода подламывай во время прозвона.
  8. стасян
    стасян Живу я здесь
    21 ноя 2008
    2.823
    ауди а4 в6 8е 1,8Т на ручке
    увалил что значит? он умер? из того что отсоединили клемму? такое разве возможно. я вас к сожалению не понимаю, что такое дамп что править и что делать потом. можете более доступно, пожалуйста
  9. стасян
    стасян Живу я здесь
    21 ноя 2008
    2.823
    melkon подскажите пожалуйста почему так много после снятия клеммы вылезло
  10. Сашкевич
    Сашкевич Живу я здесь
    29 янв 2010
    1.414
    Audi q5 3.0tdi
    Адрес 01: Электроника двигателя
    Номер Блока Управления: 8E0 910 115 A
    Компонент и/или версия: 2.0l R4/4V TFSI 01 0090
    Кодировка: 01040010190F0120
    Код мастерской: WSC 00191
    1 неисправность:
    012555 - Low Pressure Fuel regulation: Fuel Pressure Outside Specification
    P310B - 004 - нет сигнала/связи - Непостоянно - Индикатор неисправности ВКЛ
    Стоп-кадр:
    Статус неисправности: 10100100
    Приоритет неисправности: 0
    Частота неисправности: 6
    Пробег: 120036 km
    Отсчет времени: 0
    Стоп-кадр:
    Об/мин: 1282 /min
    Нагрузка: 44.3 %
    Скорость: 0.0 km/h
    Температура: 27.0°C
    Температура: 27.0°C
    Абс.давление: 990.0 mbar
    Напряжение: 13.970 V
    Готовность: 0010 0001
    2 Найдены неисправности:
    012555 - Файл CODES.dat не загружен!
    P310B - 008 - Файл CODES.dat не загружен! - Непостоянно
    Стоп-кадр:
    Статус неисправности: 00101000
    Частота неисправности: 7
    Пробег: 119999 km
    Отсчет времени: 0
    Стоп-кадр:
    Об/мин: 1195 /min
    Нагрузка: 22.7 %
    Скорость: 0.0 km/h
    Температура: 37.0°C
    Температура: 24.0°C
    Напряжение: 14.097 V
    Стоп-кадр:
    Статус неисправности: 00100100
    Частота неисправности: 1
    Пробег: 119722 km
    Отсчет времени: 0
    что делать ?
    Стоп-кадр:
    Об/мин: 3342 /min
    Нагрузка: 11.8 %
    Скорость: 0.0 km/h
    Температура: 106.0°C
    Температура: 58.0°C
    Напряжение: 13.208 V
  11. melkon
    27.090
    Сотри все и почитай то что останется . Если в приборке будет 65535 значит так и есть .это ошибка контрольной суммы еепром . Иммо не будет работать в таком режиме ...
  12. melkon
    27.090
    Ну ты же все знаешь уже .... Смотрим лог 140-107-103 и делаем выводы после этого ... Можешь позвонить еще кое что расскажу интересное .
  13. melkon
    27.090
    По какой то причине пошли пропуски по 4-му цилиндру .скорее всего в связи с этим пошли ошибки по ограничению функциональности от двигателя и АКПП . Если ошибка самоустранилась то и другие станут спорадическими .
  14. стасян
    стасян Живу я здесь
    21 ноя 2008
    2.823
    #7254 стасян, 27 июн 2012
    ой это не мне))
  15. стасян
    стасян Живу я здесь
    21 ноя 2008
    2.823
    посмотрю в приборке, но самое интересное что машину то завели и на следующий день она ездила. а сдроселем 100% не может из за лямбды или дрмв троить? или все ошибки пошли из-за дроселя?
    если в приборке 65535 то надо искать новую приборку?
  16. 052
    052 Водолей
    24 янв 2011
    6.388
    bmx
    Это он не тебе. А тебе надо слить дамп приборки и выложить сюда.
  17. стасян
    стасян Живу я здесь
    21 ноя 2008
    2.823
    каким образом? что с вашей програмой делать?
  18. Altay
    Altay Новичок
    8 июн 2011
    68
    А6/С6 2.4 04
    не могу найти расшифровку ошибки 16384?
  19. Udgin0069
    23 янв 2012
    3.747
    A4 B8 2.0T
    Дай Бог.
    Спасибо.
  20. melkon
    27.090
    Встречный вопрос - а из какого блока ошибка ?
